TephraXMOD V1
Old Jun 26, 2012 | 05:39 AM
  #766
masafina's Avatar
Originally Posted by masafina
oh ok, thank you
he got the pm full and I cant find the email
Old Jun 27, 2012 | 01:45 PM
  #767
Golden's Avatar
tephra
at
gmail
dot
com
Old Jun 27, 2012 | 03:45 PM
  #768
masafina's Avatar
thank you golden
Old Jul 10, 2012 | 08:31 PM
  #769
EvoXSly75's Avatar
Originally Posted by murlo26
I have the streetlite flywheel from ACT, which is lighter than stock (i believe) but not by much. I wanted more mass for drag anyway at the time.
I had a lot of P0300's before, like at least 1 a day, so i assumed it was my flywheel. But now with a new tune/tuner those seem to have gone away, so i am thinking it was actual misfires probably from running lean during cruise/idle.
So I am guessing the reason Tephra or people are hestitant to add a p0300 disable is it could be used for tuners to easily cover up actual problems. But might have to if lightweight flywheels really are that bad, who knows.
I got P0300 after I tuned my car, without light flywheel. When I looked at my fuel trims it was +25%. Fixed that and now the code's never came back.
Old Jul 11, 2012 | 01:03 PM
  #770
Golden's Avatar
Too bad the fuel trims max out at +12.5%.
Old Jul 12, 2012 | 04:49 AM
  #771
EvoXSly75's Avatar
Short + long trim = 12.5?
Old Jul 12, 2012 | 10:22 PM
  #772
chetrickerman's Avatar
Veteran: Army
It doesnt work that way
Old Jul 13, 2012 | 06:09 AM
  #773
EvoXSly75's Avatar
Does it annoy anyone else if I say that both my short and long fuel trims were maxed out?
Old Jul 30, 2012 | 08:30 AM
  #774
CtSilver03Evo's Avatar
Quick question on this please...
So- with Tephra7 for the IX, you need to enable the CEL flash.
With the X, do you not need to do that? Do I just specify low/high knock count values and the duration of the flash, and that's it? Or is there a value that needs to be changed to enable the CEL flash?
Thanks!
Old Jul 30, 2012 | 08:46 AM
  #775
Veteran: Army
Thanks!
Its automatically enabled
Old Jul 30, 2012 | 09:48 AM
  #776
Thank you, Sir!
Old Aug 9, 2012 | 09:25 AM
  #777
Mitsi7's Avatar
Downloaded Tephra v1 52360118(jdm 5spd) put the XML in correct folder but all I can see in Ecuflash is the following tables, no fuel, ignition or mivec maps. Also the tables that do show have no values. Any help please?
Old Aug 10, 2012 | 01:27 PM
  #778
Golden's Avatar
In the log....
[17:15:24.635] Unable to find parent metadata 5236...
You need to get a 52360018.
http://goldenevo.com/evox_view.php?rom=24
Old Aug 10, 2012 | 05:07 PM
  #779
Mitsi7's Avatar
Originally Posted by Golden
In the log....
Thanks
Old Aug 14, 2012 | 06:51 AM
  #780
Dimmoun's Avatar
On behalf of me and my tuner here in Greece just donated to donations@globalshare.net 110USD to thank you and support your efforts. We have successfully used 2008 EDM SST - 53050109 rom on my EVO X GSR SST ! Alt maps activation is done via cruise control button. Keep up the good work guys and looking forward for the SST TCU hack :-) . Regards / Dimitrios
