TephraXMOD V1
Old Jun 18, 2013 | 10:13 PM
  #826
tephra's Avatar
Originally Posted by Hiboost
So I flashed my 2011 to a 2010 rom to test the Tephra v1, everything seems to work but the transmission is shifting different as explained here:
https://www.evolutionm.net/forums/ec...tephra-v1.html
I'm going to give it a few days to see if I can either reset the battery or let the transmission adjust to the change.
2nd time someone has mentioned this - Chris - send me your VIN for your 2011. I will send you V2 to test.. You haz bench yes?
Old Jun 18, 2013 | 11:24 PM
  #827
Hiboost's Avatar
Indeed, benching is no issue for me, plus it's considered a race car now, not required for me to get to work haha.
Old Jun 24, 2013 | 11:19 AM
  #828
CtSilver03Evo's Avatar
Are there any mainstream Tephra ROMs for the 2012 or 2013 yet that have been confirmed to work? If so, Where can I get them?
Old Jun 27, 2013 | 07:33 PM
  #829
lanasa's Avatar
I am starting to touch up my alt tune for when I run my meth kit. To increase Boost on the alt map do you just increase numbers on the alt boost target 1A? Sorry, I sure its a silly noob question
Old Jun 28, 2013 | 05:52 PM
  #830
Hiboost's Avatar
Tephra, I sent you some email, is the 2011 Tephra v1 ROM still available for testing?
Cold start Normal and Sport mode are really horrible in my car, didn't notice it before since previously I went right to Super Sport. When cold and in Normal/Sport mode the car barely decides to shift and more or less combines 1st and 2nd gear, sometimes even 3rd. The engagement delay is crazy and you can barely drive the car to be honest. Luckily Super Sport makes it workable but it's not a final solution.
Thanks!
Old Jul 17, 2013 | 06:09 AM
  #831
Smoothgangsta's Avatar
+1, I have a 2013 ROM 59580004. I inquired with GoldenEvo and he doesn't have any updates. I'd be more than willing to donate accordingly to have the ability to dual map switch WITHOUT having to bench and put the 2010 ROM on my ECU. I am going in for an E85 tune next Tuesday and would like to have dual 93/e85 maps setup with the ability to switch. Does anyone have the updated .xml information to do this on the 2013 or are us 2013 owners waiting on V2 to become available for the dual map switching?
Old Jul 27, 2013 | 11:14 PM
  #832
mufasa39's Avatar
2011 gsr
tephra has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
Tephra, Could you please send me a copy of you 56890013 rom? I will donate when I can.
Thank you
Chris
Old Jul 29, 2013 | 01:23 PM
  #833
mkm492's Avatar
As soon as EVO X 2011 version is released I'll be using it (I will contribute today.) My question is can you please diagram the failsafe integration for the new HFS4 when it is released? Thanks.
Old Aug 4, 2013 | 07:04 AM
  #834
Dreamer666's Avatar
Hi, tried out the 53040110 but this value says no match...
Am I doing something wrong?
The two other mode 23 are looking good..
Mode 23 - DoMode 0x42 -> 0x52
My EDM 2008 had 53040013 before..
BR.
Old Aug 5, 2013 | 01:02 AM
  #835
Richard L's Avatar
Your fine it here (require registration):
http://www.aquamist.co.uk/vbulletin/...ead.php?t=2273
or here:
Old Aug 5, 2013 | 01:26 AM
  #836
And's Avatar
And
BR.
check the xml setting I think from memory that the scaling is wrong and it needs to be 16bit rather than 8
Old Aug 5, 2013 | 05:46 AM
  #837
mkm492's Avatar
Thanks Richard. System is working great. When Tephra V2 comes out I'll reconfigure to this.
Old Aug 11, 2013 | 03:45 PM
  #838
Dreamer666's Avatar
Hi. Have looked at this but can't find what you mean...
Could you explain how to do that?
BR.
Old Aug 15, 2013 | 07:08 AM
  #839
Eshark's Avatar
I’ve self-tuned for a few years, but I’ve never upgraded rom versions. I want to make sure I’m doing it correctly before attempting to upload the ROM.
I have a 2008 MR with an Internal ID of 52690019 and inherits 52690021. I’ve downloaded the Tephra XMOD-5260122 for the 2008 MR and have transfer all of the Timing, Fuel, Boost, etc. maps from my original ROM into the Tephra ROM.
Do I need to do anything else before loading the Tephra ROM to the ECU? Under Misc, my original ECU ID was 52690019, but under the Tephra ROM its 52690122. Do I leave this along or change it back to my ordinal ID of 52690019. Any thing else?
I know I found the answer to this question when I searching a few months ago, but now that I actually need the information I can’t seem to find the answer.
Old Aug 16, 2013 | 03:00 PM
  #840
mufasa39's Avatar
Same
I would like to know too before I pull the trigger.
