TephraXMOD V1
Old Aug 16, 2013 | 06:36 PM
  #841
Eshark's Avatar
Originally Posted by mufasa39
I would like to know too before I pull the trigger.
I have a feeling you leave the new number. When I place my old ECU ID into the field it removed the TephraXMOD V1 tables from the ROM.
I'll still wait for someone to respond that knows what they are doing.
Old Aug 16, 2013 | 09:16 PM
  #842
masafina's Avatar
As long as the first 4 numbers in the ROMID are the same then you should be good to "upgrade" to these ROM's
thats from tephra
Old Aug 16, 2013 | 11:47 PM
  #843
mufasa39's Avatar
This is what you were looking for
Jun 10, 2010, 08:52 AM #4 tephra
Personal Sales Rating: (6)
Garage is empty, add now
Drives: WW EvoX GSR
Points: 42,851, Level: 100
Daily Activity: 1.9%
Ahh you probably don't have the cranking enrichment scaling defined your evo10base.xml:
please add the following to your evo10base.xml file
Code:
<scaling name="TimeInjCranking" units="ms" toexpr="x*0.005" frexpr="x/0.005" format="%.1f" min="0" max="500" inc="1" storagetype="uint16" endian="big"/>
__________________
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - CT9A ECU mods AltMap, NLTS, KnockCEL, Valet, BIGMAPs + more
TephraXMOD V1 - CZ4A ECU mods AltMap, KnockCEL
Happy with my help? donations always appreciated -> donations{at}globalshare{dot}net
Old Aug 17, 2013 | 06:37 AM
  #844
Eshark's Avatar
Thanks
Old Aug 19, 2013 | 02:27 PM
  #845
Eshark's Avatar
Donation sent. Thanks for all of the hard work.
Old Sep 13, 2013 | 06:34 PM
  #846
E-SPEC INDUSTRIES's Avatar
Donations sent.... Thanks for the wealth of knowledge.
Old Oct 7, 2013 | 05:48 AM
  #847
zorbascreec's Avatar
I have ROM.ID 53050009 in my EVO x MR, can i use 2008 EDM/AUDM SST - 53050109 tephra mod rom with my ecu?
Old Oct 7, 2013 | 08:32 AM
  #848
mufasa39's Avatar
Yes as long as the first 4 numbers are the same 53050109 is the same with the Tephra mod that is like mine 56890009 to 56890109 which is Tephra V-1.
Old Oct 16, 2013 | 11:09 AM
  #849
lanasa's Avatar
If you want to raise your Idle which of the 14 Target Idle maps, Idle RPM, or Idle Adders do you have ti adjust?
Old Oct 23, 2013 | 05:51 AM
  #850
rrkpitt15's Avatar
WE WANT VERSION 2!!!!!! If you need another tester, let me know and ill gladly test it.
Old Nov 6, 2013 | 03:14 PM
  #851
Hiboost's Avatar
Update on 2011 Evo X MR being back flashed to 2010 Evo X MR:
Some of you may have seen earlier that I was reporting some kind of odd lag and excessive clutch slip between gear shifts especially when the car was in warmup mode. Well I finally went back and reflashed the car with the stock 2010 SST settings to see if suddenly the issue went away... and it did!
So what might have yielded perfect drivability and quick off the line response on a 2011 SST rom, this was not the case taking those same SST settings and directly copying them to the 2010 tune. I plan on doing one or two groups of tables at a time until the issue suddenly comes back. It was very noticeable when the car was trying to shift from 1st to 2nd on a cold start, it would hover in limbo for several seconds sometimes and you almost had to let off for a few seconds for it to sort things out.
I got into full boost in 4th to see if the clutchpacks would slip or open up at WOT and somehow it was ok, at least at 25 psi, but I did feed in the throttle instead of letting full torque hit at 3500-4000 rpm. I can definitely tell the car is sluggish off the line though and that is what some of the SST tweaks addressed as well. Chances are I'll just keep the tables close to stock up until 30% TPS which will keep drivability good and avoid the lagged out super slipping that was happening before.
Once I figure out which set of tables is the culprit I'll report back of course.
Old Nov 6, 2013 | 03:29 PM
  #852
tephra's Avatar
Chris - drop me an email i would be interested in you testing V2!
if you are that is
Old Nov 7, 2013 | 08:45 AM
  #853
Hiboost's Avatar
if you are that is
Will do, I did send an email last time you asked about it but it must have gotten lost.
Old Nov 18, 2013 | 12:10 PM
  #854
acmotor's Avatar
Hi guys , i need help ... i got into limb mode while sudden full throttle . EVOscan show p1235, p1238, p1241. even i flash back to ori Rom i still get the codes .
EVO X SST 2008 - ROM ID 52370028 . tried using TephraXMod 52690122 car drive without problem , but just sudden full throttle when on highway .
Can anyone help me out with this matter ?
Thanks
AC.
Old Nov 18, 2013 | 12:19 PM
  #855
RazorLab's Avatar
Turn off the torque/airflow limiters.
