TephraXMOD V1
Hi Guys,
I bought an Evo x that came with a Tephra V1 ROM...
I'd like to use Mode 23 for logging but I dont have de XML file definition for ecuflash.
Could you help me?
The rom is attached.
Thanks!
Roberto
Could you help me?
Thanks!
Roberto
Hi tephra, my name is Roberto...
I bought an evo x and I'm using 57140101 xmod v1...
Amazing ROM!
It was just installed in my ecu, but I think the right thing to do is to pay for it...
I'd like to know how to pay and if you can send me a "virgin" .hex and .xml...
Id like to start tuning from zero...
TX
Amazing ROM!
TX
The donate links work. I get not wanting to just send money and not know if you will get a response back, but I got a pretty quick response back (few days) after buying v3 last year.
AEM meth safe help!!
Fixes
ok some scalings have been left out - if you have a stock ECUFLash then you will need these
Please copy/paste these into your evo10base.xml
FAQ
Its taking a long time to flash, is this normal? - Yes, A lot of blocks in the ROM has changed, so ECUFlash will take quite a lot longer than usual to flash all the updated blocks..
Does cruise control still work? - Yes
How many sets of maps can I swap? - At the moment, 2, so your stock one and then an alternate set
Whats the best setup for a meth failsafe? - You should use one of the ADC modes, if your USDM then you have to use the resistor ADC mode. Both ADC modes will switch back to normal maps INSTANTLY on detection of the failsafe condition.
Here is the wiring setup you should be trying to use for a meth failsafe:
Aquamist HFS Controller Setup
AEM Controller Setup
Code:
<scaling name="VoltsADC1023" units="Volts" toexpr="x*5/1023" frexpr="x*1023/5" format="%.2f" min="0" max="16" inc="0.05" storagetype="uint16" endian="big"/> <scaling name="TimeInjCranking" units="ms" toexpr="x*0.005" frexpr="x/0.005" format="%.1f" min="0" max="500" inc="1" storagetype="uint16" endian="big"/>
FAQ
Tephra V1 for ROM 52680122 has Alt Fuel Injector scaling parameter under TephraXMOD V1, to adjust injector size for different tune/fuel.
The ROM also has following parameters under Misc:
Fuel Injector Scaling Replacement
Fuel Injector Scaling AltMap #1 Replacement TV3
Fuel Injector Scaling AltMap #1 Replacement TV1
Injector Scaling Rescale #1 - 5
Does anyone know what the parameters under Misc. are to be used for?
evo 8 FQ320
hi there, i recently bought a evo 8 FQ320 and was wondering what rom would suit my car, need some pops and bangs as well and bit of power :-) . any assistance would be appreciated, thanks in advance.
