Virtual Dyno - Standalone Software
Old Aug 31, 2012 | 11:57 AM
  #1486
dawnduran's Avatar
Originally Posted by bbarnhill
Hum ... Im working on one ...
I Asked before Download.
Sorry.
How can i make a New Car to the List?
Old Aug 31, 2012 | 11:09 PM
  #1487
bbarnhill's Avatar
Is it a custom car or a stock cars specs?
Old Aug 31, 2012 | 11:37 PM
  #1488
dawnduran's Avatar
Its a Nissan Pulsar GTiR with custom specs and a Mitsubishi Galant 2.5 V6 NA (160hp)
Old Sep 1, 2012 | 07:58 PM
  #1489
bbarnhill's Avatar
you can create custom XML files and put them in the customcars folder in the data folder right now. If I ever get to finish the custom car editor itll save them right to the custom car folder for ya.
Old Sep 4, 2012 | 09:05 AM
  #1490
busky2k's Avatar
I'm noticing consistently lower results with VD 1.1.9 and no fiddling with the smoothing gets me the same results as 1.1.8. Runs are anywhere from 5 to 10kw lower, however the occasional log is spot on. I know only the smoothing has changed but I want to revert back to 1.1.8 to double check again. Can I grab a copy of the old version?
Old Sep 4, 2012 | 10:14 AM
  #1491
Boosted Tuning's Avatar
1.1.9 is more accurate, even though it reads low. Its better to have it accurate, then inflated.
Also, as you know the smoothing changed. If you used 3 in 1.1.8, then you use 2 in 1.1.9.
Old Sep 4, 2012 | 07:00 PM
  #1492
busky2k's Avatar
Yeah not too worried about the absolute numbers but it just seems weird to work with runs that have different power figures from before since I label my CSVs according to their peak power eg "276kw.csv". I used 3 smoothing in v1.1.8 although trying 1 or 2 in v1.1.9 doesn't line up. Either way, just a heads up for those who haven't noticed...
Old Sep 4, 2012 | 08:25 PM
  #1493
bbarnhill's Avatar
the power calculations havent changed since 1.0.0.1
Old Sep 4, 2012 | 08:34 PM
  #1494
True, but the smoothing algorithm has changed and 1.1.9 did read slightly lower. Regardless, I feel it made the program more accurate.
Old Sep 4, 2012 | 08:44 PM
  #1495
wizzo 8's Avatar
I agree
Old Sep 5, 2012 | 05:49 AM
  #1496
bbarnhill's Avatar
The smoothing algorithm changed for the side of correctness ... it was just flat wrong before.
Old Sep 25, 2012 | 04:30 PM
  #1497
Tmosser's Avatar
Does this work with mitsulogger?
How exactly do you set it up/use? I cant get it to work.
Old Sep 25, 2012 | 09:20 PM
  #1498
LOL, actually I dont think it does support mitsulogger. No one really uses it. If you send Brad a mitsulogger log, he could probably impalement it. His email is prob somewhere in this thread.
Old Sep 26, 2012 | 05:53 AM
  #1499
bbarnhill's Avatar
actually my email isnt in the thread to keep crawlers from finding it. I can PM you my email address if you want. If you want it just PM me and Ill respond.
Old Sep 26, 2012 | 08:26 AM
  #1500
Tmosser's Avatar
Well i removed and re installed it. It worked and uploaded a mitsulogger log and it showed my power/tq it just said evoscan on the side of the table brad, if you want to verify it shoot me your email and ill send you a log.
Do you have to have internet connection when uploading a log to vd? I notice when you start up it tests for internet.
