Virtual Dyno - Standalone Software
Mellon if you can help me get the correction factors or some of the stock gear ratios and things of that nature we can get this thing finished. I have been needing some help in that department for a couple of months now but I keep getting no where with it. I wish there was a reliable place to get the info from..
Updated a few of the vehicles. Added a donate button and sorted the dropdown of vehicles (that was bugging me).
Check the corrected values and let me know if I got something wrong guys.
I need to compare some data logs for multiple runs on the same dynos to get the correction factors to add to my dropdown list in the settings screen. Its just like getting blood from a turnip to get data from people.
Get YOUR car weighed and then everyone can finally have that info
There has to be a ton of truck stops down in NC, most will have a truck scale and its about $5-9 to get a car weighed. THey are usually very accurate but only go in 15lb increments but thats not significant enough to throw off the HP enough to be concerned.
I'm an SSL, that's why I did a ton of research short of actually weighing my car.
Unfortunately for me, I have 0 weight savings..actually probably weight additions.
But my car is my daily driver, so I don't try to take weight off the car at all. Heck, seeing that I got SSL, I think you can tell that.
yea the only weight reduction i have is replace the cat with a test pipe for my summer trim, as for the rest of the year i dont think i have any weight savings since i got a 37lb catback haha
Yeah, haha. I have stock cat-back with an e-cutout, so added weight there. I have an ETS 3.5" IC, so added weight there. I have a CarPC, so again, added weight there.
All of the other mods are just replacements of like parts, like cams, for example.
So, when I use VDR for my SSL, I use about 3365 for my weight, depending on how much gas, etc. I know I have a heavy Evo and not sure how close that number is to reality (I was very tempted to just get it weighed at a local truck scale, but figured the accuracy just wasn't worth it), but as long as I use that same number and just adjust for how much gas is in the tank, then I can use the tool for comparisons, as it was intended.
All of the other mods are just replacements of like parts, like cams, for example.So, when I use VDR for my SSL, I use about 3365 for my weight, depending on how much gas, etc. I know I have a heavy Evo and not sure how close that number is to reality (I was very tempted to just get it weighed at a local truck scale, but figured the accuracy just wasn't worth it), but as long as I use that same number and just adjust for how much gas is in the tank, then I can use the tool for comparisons, as it was intended.
3338 was the number i found for a evo 9 with ssl
3219 was the number for evo 9 rs
3175 was the number for evo 8 rs
I cannot for the life of me get the software to accept my data log. I have tried saving it in several different types of .csv files in Win7, but none work. It keeps saying E101, not all columns needed are present. I only have two colums; Seconds (sec) and RPM (RPM).
Any ideas, what am I doing wrong?
