Tephra v7 tps map switching
Old Jul 17, 2010 | 09:56 PM
speifer's Avatar
Hey, I'm running my E85 maps as main and gasoline on the alternate using TPS to switch between them. If I'm on the alternate map and upload a change, will the ecu revert back to the main map? Thanks.
Old Jul 18, 2010 | 07:20 PM
Jeff_Jeske's Avatar
You could test this by setting the boost (WDC) to zero in one of the maps. After a simple test you would know.
Old Jul 21, 2010 | 06:00 AM
speifer's Avatar
Follow up: The map defaults back to the main map when updates are uploaded.
Old Jul 22, 2010 | 12:38 AM
tephra's Avatar
yeah I think I did that on purpose.
just check the ICS light flashing to see what map your on
Old Jul 22, 2010 | 02:12 AM
Toxin's Avatar
Tephra The legend
Old Jul 22, 2010 | 07:49 AM
speifer's Avatar
+1 to Tephra being awesome.
I have a USDM IX though, so I don't think I have an ICS light.
I was able to tell which map I was on by looking at my wideband during idle; I could tell it was on the E85 map while running 93 octance because it idled very rich.
Old Jul 22, 2010 | 08:00 AM
TouringBubble's Avatar
Actually, I've seen different responses on an Evo VIII and IX with the V7 ... at least I think I did. the VIII I worked on kept the map switch setting and the IX did not. Both used the TPS switch. Maybe I'm mistaken. Obviously, Tephra knows what happens better than me, but I seem to remember this conflict.
It's something that slips by sometimes when you're not tuning too often, and you're all "WTF happened to my map?!?"
Old Jul 27, 2010 | 05:06 AM
pug206's Avatar
I habe a EvoIX edm and if you habe light ics.
Old Jul 27, 2010 | 08:50 PM
tephra's Avatar
um its been a long time now, I did think the US had an ICS light... but maybe not?
Old Jul 28, 2010 | 08:19 AM
Appauldd's Avatar
Tephra,
For USDM evos only the 03 and 04 have the ICS. After that the cars got the ACD so the ICS was scrapped.
c0ke
Aug 28, 2013 06:30 AM
211Ratsbud
Nov 3, 2012 03:19 PM
BluEVOIX
Mar 31, 2011 03:55 PM
Maikumaru
Mar 6, 2011 05:02 PM
Seijuro
Mar 18, 2010 03:09 PM
