map switch help
Old Jul 6, 2009 | 04:27 PM
Maikumaru's Avatar
map switch help
Hope someone can help
I installed the map switch in my car (from jack of trades)...but the map does not switch until about 30 minutes of driving. I have been searching on here and cant find an answer...
how I know this...was driving on the free way with map switch light on (alternate map) and after about 30 minutes or so, it switched to the alternate map.
I switched the map to off and it moved immediately back to the primary map (high octane). switched back to low octane...and no switch again for about 30 minutes.
One gentleman suggested
i had to change the alternate map load threshold lower to enable my alternate map on the fly faster...
But this is not working.
ROM ID
88590015
any suggestions?
Old Jul 6, 2009 | 04:34 PM
tephra's Avatar
ecuflash version?
tephramod version?
tephramod settings?
Old Jul 6, 2009 | 04:37 PM
surferjeff's Avatar
subscribed
Maikumaru's Avatar
dont know off the top of my head...dang it.
Old Jul 7, 2009 | 11:44 AM
Maikumaru's Avatar
Here are the versions
tephra V5 and ecu flash 1.41
Old Jul 7, 2009 | 12:00 PM
Maikumaru's Avatar
What settings are you looking for?
This has been done as well; ADC0f input-->should recognize the intercooler pin.
Old Jul 7, 2009 | 03:28 PM
Maikumaru's Avatar
oh yea alternate map time is set to 0...
Old Jul 7, 2009 | 04:05 PM
tephra's Avatar
dont set it to 0, i think try 1 step above zero
Old Jul 7, 2009 | 04:32 PM
Maikumaru's Avatar
Ok I will try it in when I get off work...
lol it usually is something easy like that.
Old Jul 8, 2009 | 11:43 AM
Jack_of_Trades's Avatar
This confused me. You found the totally separate Alternate fuel/ignition maps in the TephraMod section right? You're car isn't switching between the high octane and low octane maps when map switching, its switching between the standard fuel/ignition maps and the newly added maps in Tephra's MOD section. Just wanted to be sure.
Old Jul 8, 2009 | 12:08 PM
Maikumaru's Avatar
First off to Tephra-->changed from 0 to 10ms and still did not work...
Hello Jamie,
Yes my mistake on that one. The tephra mod alt map is being used.
Any ideas...???
Old Jul 8, 2009 | 12:46 PM
Have you searched on this forum or the wiki page on how to datalog which maps are active (alt maps or standard maps) and also datalog the input voltage at the ADC0F input to confirm its getting enough voltage? What voltage do you have the alt-map switching set to? Its 3.01 volts by default and should be well below the voltage of the harness. The harness supplies between 4.6-4.9 volts.
Old Jul 8, 2009 | 02:17 PM
Maikumaru's Avatar
I have not done any data logging on which maps are active.
I have not checked the voltage of the adc0f input. I have not altered the voltage of the alt map switch.
guess I have homework then
Old Mar 6, 2011 | 05:02 PM
anexiole's Avatar
interesting read. So, the problem is solved now?
tephra
Sep 13, 2021 01:07 AM
egis
Jan 6, 2016 07:55 PM
Icem@n
Feb 15, 2012 09:58 AM
clockworktoy
Dec 11, 2011 12:20 AM
MadMsheen
Jan 7, 2011 02:47 PM
