Tired of looking for the right answer.. IX rpms hang up when shifting
Old Sep 21, 2010 | 02:42 PM
  #31
Boosted Tuning's Avatar
Originally Posted by itzwolf
Why not publically share something like this?
Now to answer this question.
I dont know what it is with a vendor badge, but as soon as you get one, it seems if people are always looking to make what you say look wrong. (see example above.)
This is WHY I dont always post things publically and is leading to me posting even less tips and tricks.
Tell all the haters thank you.
Old Sep 21, 2010 | 03:36 PM
  #32
esevo's Avatar
You know your entitled to your opinion. But there are other ways to tune. Just like scaling injectors. Many methods no answer that's 100%.
I personally have seen no difference between adjusting the two different tables. Like always, written form of communications leave us to assume each others moods. I was being playful not rude. You read it wrong sorry. I felt mis understood and I do know as I have read all these threads. So the evo 8 debate led me to be firm but not trying to be rude. Im sure your experience is creditable, but the fix I posted worked for me and other costumers. If I run into a car where it doesn't work completely I will admit it and use the decel tables as well. But it has been needed for me yet.
Evan Smith
Old Sep 21, 2010 | 04:03 PM
  #33
Evan Smith
Nevermind. Keep doing it the incorrect way. Im done here....
Old Sep 22, 2010 | 06:44 PM
  #34
evoRS06's Avatar
Where is the mod now? Lol, silliness, but thanks to those who added valuable top secret information
Old Sep 23, 2010 | 04:47 PM
  #35
Nasty Evolution's Avatar
I'm still looking for a link for the xml data to download.
Old Sep 23, 2010 | 05:32 PM
  #36
https://www.evolutionm.net/forums/ec...ttle-hang.html
Old Oct 11, 2010 | 07:27 PM
  #37
Ok, thank you all so far.. I finally got around to adding the .xml files so I can adjust the fuel cut tables. I have 4 tables, cut 1 cut 2, and two others. What values do I want to change to? I tried to follow another thread listed in the link but was still kinda unsure of it all.
Old Oct 23, 2010 | 03:33 PM
  #38
AutoXer's Avatar
Regarding Decel Fuel Cut Delay:
What is it's purpose and do we need it?
Here's what I know. Most cars cut off the injectors if TPS=0(or close to it) and RPM>several hundred RPM above idle. So even though there is a small amount of air getting to the cylinders, the injectors are completely cut off. Those with a wideband will see this during deceleration when the AFR goes off the chart lean (or starts reading % oxygen).
The fuel cut delay essentially delays when the injectors are cut off. You can see the delay on a wideband.
When the throttle snaps shut, there is still a path for air to get through... the idle air bypass. This is why making adjustments to the ISCV tables affects this problem. The problem would be compounded if the BOV was not opening properly. You'll have a higher differential pressure between upstream and downstream of the throttle butterfly. Which would mean more air getting through to the cylinders. Running higher boost with a problematic BOV would make it even worse.
Why is the Load on the Load vs Delay table limited to 70? This doesn't make any sense to me. The hang usually isn't a problem for me below a load of 100.
So, again... What is it's purpose and do we need it? Has anyone tried zeroing out the delay table?
Old Oct 23, 2010 | 03:48 PM
  #39
JohnBradley's Avatar
Notching the timing map is the single most effective way to cure the issue.
aaron
Old Oct 23, 2010 | 05:37 PM
  #40
It was revealed by mrfred last week that the "decel fuel delay" tables are actually ISCV tables.
So it all comes to ISCV tables, the "decel fuel" ones and the RPM adder ones.
The original theory of why the decel fuel tables was that the ECU was still dumping fuel into the engine and helped caused the hang. It turns out that wasnt the case.
Old Oct 23, 2010 | 06:13 PM
  #41
AutoXer's Avatar
Thanks! Can you link to the post?
Edit:
I found it... https://www.evolutionm.net/forums/8744106-post133.html
Old Oct 24, 2010 | 01:17 PM
  #42
So I should just go back and change my fuel cut delay tables back to stock?
What do you mean "notch" the timing John Bradley? Thank you in advance.
supasixfo
Jun 2, 2015 06:01 PM
00evo00
Aug 12, 2014 05:54 AM
Redstang69
Lancer Engine Tech
Nov 13, 2013 05:33 AM
webguy330i
190
Oct 4, 2013 11:32 AM
kvinh90
Apr 17, 2011 09:35 AM
