help! TephraMod saving wtf
Old Sep 4, 2010 | 02:01 PM
gallas's Avatar
Ok i have been fighting with this damn TephraMod-recompile.bin mod for over a week with absolutely no luck and still having the same issue. whenever i change anything such as the immobilizer over from my current rom then save it, close it, and reopen the same TephraMod-recompile.bin file it's back to the stock rom format with none of the mod options. i was able to successfully save after a few changes but soon as i do anything major it resets. can anybody do me a huge favor and swap over all my maps and data plz ive tried everything and have transfered all these maps at least 6 times. I just want this damn upgrade
Old Sep 4, 2010 | 02:29 PM
mt057's Avatar
I could not change mine intil I disabled user account control in windows. Before that I could not change the rom data.
Old Sep 4, 2010 | 02:34 PM
gallas's Avatar
I have my UAC turned off and have tuned it off in the directory also...
Old Sep 4, 2010 | 09:36 PM
mt057's Avatar
Also make sure that there are no old copies of the Rom lurking about. Is the Rom reverting back to the original version with no tephra mods available, is that right? What Rom are you running?
Old Sep 4, 2010 | 11:25 PM
gallas's Avatar
ive gone as far as renaming and removing my original rom file 88590015 in hopes that it would have no rom to revert back to.
Old Sep 5, 2010 | 11:20 AM
03RRVIII's Avatar
it think i know what your doing wrong, it happen to me before. all you need to transfer to the V7 rom is your Immobilizer, & Init# only then save it, close it and re-open it.
Old Sep 5, 2010 | 06:50 PM
gallas's Avatar
i have done that and it worked but as soon as i changes anything big such as timing it resets when i save it... i have tried every thing that has been posted so far lol..
Old Sep 8, 2010 | 06:57 PM
element26's Avatar
yeah i was having this issue too. i ended up deleting almost everyting and starting from step one over again. havent had a problem since.
Old Sep 8, 2010 | 07:05 PM
nightwalker's Avatar
If you're using the latest windows, you have to disable some of the security features.
Old Sep 8, 2010 | 07:14 PM
Jack_of_Trades's Avatar
Have you edited it and saved as a unique name and then tried re-opening it under the new name?
Old Sep 9, 2010 | 08:06 PM
gallas's Avatar
yes i have done all that. i just reformatted my computer and went to the 64bit so im gona give it another shot in a min.
Old Sep 9, 2010 | 08:29 PM
gallas's Avatar
nope i changed my immobilizer code and saved and it saved fine. soon as i change another value anywhere tho it resets back to stock rom
Old Sep 11, 2010 | 12:23 PM
esevo's Avatar
Did you change your ECU internal ID??? DONT copy your stock id in or when you save it, it reverts to a stock rom.
Evan Smith
Old Sep 11, 2010 | 02:41 PM
gallas's Avatar
Evan Smith
I think that mite be it.. im gona clock out of work and go try it.
Old Sep 11, 2010 | 03:51 PM
gallas's Avatar
Ok yeah that was the problem. now i noticed that my rom is measured in Celsius and the tephra is in Fahrenheit. suspect some of the changes i mad were to already correct cells because i didnt see a fahrenheit in the tag.. does anyone know if i can just transfer my timing maps, immobilizer and be good? i have a tuned rom not quite sure what data was changed. or even better a way to change a setting in ecuflash so both roms read in fahrenheit so i can just confirm it myself?
