Torque seems low and late
Old Sep 7, 2010 | 06:27 PM
LGshow19's Avatar
You hook the hose that's connected to the WGA nipple to the compressor... Bam the WGA extends and shuts the flapper closed completely...
Understand now?
Old Sep 7, 2010 | 07:05 PM
EvoPower81's Avatar
yeah but its still not practical
Old Sep 7, 2010 | 07:35 PM
LGshow19's Avatar
How is it not practical?
-U disconnect the vacuum hose that connects to the MBC(leave it connected to the nipple on the WGA)
-use the air hose to pressure the WGA and let it fit tight onto the flapper.
*if u try to put the WGA onto the flapper by hand its gonna be slightly open... That's what my problem was.. You could really tell since I had a o2 dump
I don't know if u get it now, but I'm just trying to share experince...
Old Sep 8, 2010 | 09:24 AM
Jack_of_Trades's Avatar
I see what you are saying. You take an air gun nozzle and apply air pressure to the WGA inlet to help push the rod out because a proper adjustment would place the hole on the actuator rod slightly behind the flapper stem. I usually just use a pair of vise grips on the WGA rod and give it a good tug to get the rod over the stem on the flapper.
I thought you were saying to hook it up to the compressor side of the turbo, not an air compressor in a garage.
Old Sep 8, 2010 | 10:54 AM
EvoPower81's Avatar
x2
Old Sep 8, 2010 | 12:27 PM
LGshow19's Avatar
Lol, man I was like WTF!!!
Did u get the problem fixed?
Old Sep 8, 2010 | 12:58 PM
EvoPower81's Avatar
Did a boost leak today and found 1 by the silicone hose attached to the throttle body. Its amazing where you find leaks. Had a t-bolt clamp in that position but no matter how i tighten the leak wont go away. had to use a normal screw clamp. Have had chance to change the WGA as yet. Will keep you posted
Old Sep 8, 2010 | 01:40 PM
Understand now?
When you apply air to the WGA, it extends...'opening' the wastegate flapper, it doesn't close it. That's how the system works. As boost pressure rises past the wastegate spring pressure, it opens the flapper to regulate boost pressure. Unless of course you meant it closes AFTER you release the air pressure
Old Sep 8, 2010 | 02:39 PM
LGshow19's Avatar
Yea it closes after you release the air pressure... Pressure opens the WGA, which extends the WGA so it can connect to the flapper, then you stop the air flow which closes the WGA... Bam done
Old Sep 8, 2010 | 03:05 PM
Appauldd's Avatar
I just use my hands....pull the WGA rod onto the WG flapper. Tighter isn't always better though. I found with my 18psi WGA that only enough to barely hold the WGA shut is the best setting.
Old Sep 8, 2010 | 03:39 PM
You want it just tight enough to hold pressure correctly. If you go too tight it can lead to boost spikes.
Old Sep 8, 2010 | 07:21 PM
EvoPower81's Avatar
This is true.
Old Sep 8, 2010 | 08:09 PM
LGshow19's Avatar
FP 25psi WGA... Peak boost is 28psi at 3100rpm holding to 25psi or so to 7k rpm ... 9turbo+e85=fun!!!
Old Sep 9, 2010 | 01:13 PM
EvoPower81's Avatar
Does my HP and Torque look correct for 25 psi with 50/50 348whp/319 torque! Should i try to switch from the 1.0 jet to the 0.8?
Old Sep 9, 2010 | 02:54 PM
Take that power curve in your first post and throw it out of the window. When you fix your WGA issue, your power results are going to completely change. As well as your tune so be sure to plan on a full retune once your torque comes back.
