urgent help quick
Old Oct 14, 2010 | 09:16 AM
sleeper04's Avatar
urgent help quick
ive been able to read write to my ecu and just this morning i tried uploading a new map, i get some error that says see log for details same thing with trying to write to it???? also if i try to log through evo scan it says no response from vehicle ecu?? also the car wont start? hope the ecu is wasted? anythign guys
Old Oct 14, 2010 | 10:29 AM
hediki12's Avatar
check fuses (usually an interior light fuse),make sure your battery isnt dead/has enough juice and make the reflash cable is actually hooked up properly. can it log?
Old Oct 14, 2010 | 10:51 AM
sleeper04's Avatar
tried that in ecu flash says no response from vehicle ecu??
Old Oct 14, 2010 | 11:01 AM
gsrboi80's Avatar
Make sure you have enough battery power, after that which cable do you have??
Old Oct 14, 2010 | 09:09 PM
sleeper04's Avatar
the 1.3 ive used you 50 times before haha..trying to charge the battery now
Old Oct 15, 2010 | 12:54 AM
Boosted GP's Avatar
I have found if logged Voltage is below 12v the ecu will not flash and logging becomes inconsistant in terms of connecting
Mike
Old Oct 15, 2010 | 10:52 PM
sleeper04's Avatar
the first time i tried to jump it the car just cranked and cranked, the second time it started. anyone have any experience with fuel pumps working then not working before the go out??
its a walbro 255 about a year old
Old Oct 15, 2010 | 11:58 PM
hediki12's Avatar
switch the key to acc. and you will hear if it primes.. if it primes its working..
Old Oct 16, 2010 | 12:26 AM
And's Avatar
And
do you need ecu unlocker to read your ecu?
Old Oct 16, 2010 | 12:59 AM
hediki12's Avatar
no only when its locked by a tuner...
ilikeppie
Jul 7, 2021 03:10 AM
stunt2
Sep 28, 2015 03:15 PM
jcsbanks
Apr 28, 2008 11:54 AM
jdmevo8313
Apr 15, 2007 05:18 PM
