V7 fuel cut
Old Oct 15, 2010 | 01:51 PM
F0RSAKEN's Avatar
V7 fuel cut
What are all of the parameters in v7 (88591715) that can cause fuel cut?
I get it after a 7000-8000rpm WOT run, but after I lift off throttle. When I shift into the next gear, it cuts hard. Logs show 0 for injector pulse and IDC. Takes a couple seconds before recovery.
Stock turbo, 25psi, 880cc injectors with walbro 255.
Ideas?
Old Oct 15, 2010 | 02:21 PM
VGergo's Avatar
no lift to shift enable ?
Old Oct 15, 2010 | 04:31 PM
F0RSAKEN's Avatar
Meaning is it enabled/disabled? I'll have to look, all I changed in the map was fuel injector scaling for the injectors, and the fuel/ignition map.
Would NLTS cause this, even if I lifted to shift? Also, my clutch switch is disconnected. Does that matter?
Note: The fuel cut tables themselves are stock as per v7's base.
Old Oct 15, 2010 | 10:59 PM
oldevodude's Avatar
stock v7 has stock fuel cut (I'm pretty sure) so if you have mods that might be your problem. search on Evom for where to change it if you do not know how.
PS I'm sure there are plenty of tuners that are willing to charge you for their services as well
Good Luck
Old Oct 15, 2010 | 11:24 PM
F0RSAKEN's Avatar
Good Luck
I think the first reply was onto something. I disabled the NLTS in v7 options, reflashed the car, and it didn't do it anymore. I'll give it more time before I accept that as the fix.
Old Oct 16, 2010 | 12:01 AM
hediki12's Avatar
if your gonna drive with nlts you have to make sure you raise the parameter to were it will ONLY engage at WOT/haul-*** mode and not peppy/sporty driving..
btw like your icon i tell my kids that all the time
Old Oct 16, 2010 | 07:24 AM
toysgetsmoked's Avatar
I was getting the same issue with the nlts option turned it off and went away I even adjust the values and still did it..
ReidFletcher
Apr 27, 2017 01:03 AM
101516
29
May 4, 2014 05:28 PM
lancerMXV6
Aug 20, 2013 08:06 PM
Dochka
Aug 18, 2011 04:37 PM
erik.bouse
12
Dec 12, 2010 02:39 AM
