Evo cutting out at high boost
Old Apr 25, 2014 | 02:42 AM
101516's Avatar
Hi all,
My car is cutting out at boost higher than 26. I have 6766 turbo and ets turbo kit, fuel system twin pumps, I have sparktech coils and change plugs gaped them to 0.020 and nothing change. The battery voltage is 13.9 all the run. Injector duty cycle is 61%.
I changed the grimspeed and the waste gate. I did boost leak. I checked all safety features on my aem v2 like fuel cut and ignition cut. Its something strange. The only thing will make the difference when the cut out will happen if I change my waste gate duty cycle. It will cut randomly on different rpm. I am sure its a boost problem.
Any suggestions!
Old Apr 25, 2014 | 01:10 PM
foxbat's Avatar
What kind of spark plugs are you using?
Old Apr 25, 2014 | 01:20 PM
101516's Avatar
I tried both BPR8EIX and BPR8ES. No difference.
Old Apr 25, 2014 | 02:20 PM
jr_2006IXMR's Avatar
Evo 8 or 9?
Old Apr 25, 2014 | 02:24 PM
rongdoer's Avatar
Do you have a 15 amp ignition fuse to replace the 10amp under the dash? I just fixed a fuel cut issue by doing that because of my spoolinup cop. Funny thing was it didn't have a problem for 4 years until I advanced the timing. Then around 5k rpm under boost it would stutter and missfire, and the cel would come on. It was throwing a p0300. There's another thread on here about it.
Old Apr 25, 2014 | 02:51 PM
foxbat's Avatar
A data log would help determine whether it's an ignition or fuel cut, a first step to diagnose the issue.
Old Apr 25, 2014 | 03:29 PM
slowsrt4:('s Avatar
yes do some logs
Old Apr 25, 2014 | 11:53 PM
101516's Avatar
It's an evo 8. I have Aem V2 ems and not the stock ecu.
Old Apr 25, 2014 | 11:57 PM
Faisalm's Avatar
You can still log with the AEM EMS V2...
Old Apr 26, 2014 | 12:51 AM
101516's Avatar
I called my tuner now and he said its a fuel cut.
Old Apr 26, 2014 | 02:28 AM
foxbat's Avatar
Is your tune speed density based? One possibility is a faulty map sensor.
Old Apr 26, 2014 | 02:34 AM
101516's Avatar
I replaced the MAP sensor. same problem. My tuner is now checking the dwell time for aem v2.
Old Apr 26, 2014 | 03:01 AM
foxbat's Avatar
Dwell time! You said it's a fuel cut.
Old Apr 26, 2014 | 02:42 PM
101516's Avatar
I did change it. Still same problem.
Old Apr 27, 2014 | 01:13 AM
foxbat's Avatar
If the tuner is saying it's a fuel cut & you have nothing, physically wrong with the fuel system then it has to be a tune/ECU issue. Did the problem start after you got the car tuned?
