962 Rom not working with a edm E8
Old Aug 18, 2011 | 04:08 PM
Dochka's Avatar
Hi, I tried flashing the 96200009jdm rom and the v7 tephra version of it to different evo 8's but the engine doesn't start or starts then cuts fuel after a second...
I disabled the immobiliser via the periphery bits, but that doesn't work too;
Anyone can help
Also the deceleration fuel cut off, doesn't work within the 96530006 v7 whatever i put different values...
If using another roms , i patch the ecu periphery xml, then put the value to 56d2 instead of 56d8, but the engine dies after 2 sec after it starts...
Old Aug 18, 2011 | 04:18 PM
ziad's Avatar
a silly question is the valet mode turned on? and is the rpm limit set at 112 or whatever small rpm it is set by default????
Old Aug 18, 2011 | 04:37 PM
Dochka's Avatar
Ziad, i was having trouble with making the launch control work with the 965v7 and patched your xml mod and it worked...
Ur great man, thanks a lot
Na, nothing of the above is current, valet mode is turned off, rpm limit is 7800rpm...
mrfred
Feb 26, 2022 06:16 PM
mrfred
Sep 17, 2017 06:11 AM
besk
Jan 23, 2017 01:05 PM
A1hunter
Dec 15, 2015 12:44 PM
Appauldd
Sep 21, 2015 08:39 AM
