Ultimate Alt Maps
Old Nov 18, 2010 | 07:03 AM
  #31
murlo26's Avatar
No NLTS 1/4 mile guys love this...
Did you mean this release or ever?
Old Nov 18, 2010 | 07:14 AM
  #32
tsitalon1's Avatar
Originally Posted by tephra
yeah I wont be doing ALS or NLTS... I don't think either is all that useful...
ok so on the MIVEC - is the high/low the best way? I can't really see people using (nor wanting to use) more than high/low maps...
I will still include 8 of them as altmaps thou...
Yes, I think high/low is the best way.
Would there be an advantage to have high/low for timing?
Old Nov 18, 2010 | 08:02 AM
  #33
Golden's Avatar
High / Low sounds good to me. Would it just use the same speed crossover point as the other tables?
Old Nov 18, 2010 | 09:41 AM
  #34
Clipse3GT's Avatar
I think it would have to be the same as the boost crossover.
Old Nov 18, 2010 | 11:16 PM
  #35
fostytou's Avatar
EvoM Community Team
I meant to imply this before, but I would personally prefer if we could keep the settings different. I really only want different MIVEC for my cruising gear, but obviously I want boost to be switchable 1-2 and 3-5. Ideally each gear would be tunable if it were up to me, but I'm one of the guys who likes to have really low settings at peak TQ in 5th gear for when other people with a heavy foot drive my car.
ALS would be cool, and if people want to blow up their turbo with it more power to them. Beyond a quick disclaimer (which really shouldn't even be necessary, if people want to try things without reading about them there are 1000 ways to blow up your car) it is up to the end user. In the end, I'm meh about it if it delays anything else... but I'm guessing it would helpful to some of our rally guys.
NLTS is a really nice feature, I'm not gonna lie... but the faux NLTS should work ok for most 1/4 mile guys... the only problem is that you cannot do a distinct setting for launch and drop RPM.
Old Nov 18, 2010 | 11:22 PM
  #36
tephra's Avatar
yeah the crossover for MIVEC will be a seperate item (ie not linked to the boost xover)
Old Nov 19, 2010 | 12:15 AM
  #37
kozmic27's Avatar
I didn't see lower bound ignition on the first post, though I recall you mentioning adding it in another thread. Is it going to make the list?
Old Nov 19, 2010 | 08:24 AM
  #38
rrkpitt15's Avatar
Are you going to do any cool safety features.... like valet mode or AFR safety (like you have for the 8 & 9's). With our ****ty fuel pump relays i think that would be nice for the daily drivers. I have a buddy that took his wife to the hospital when they were having their first baby and the hospital had valet parking. When he came out about 6 hours later (she was in labor for 30 hours) to go get them some food, he was leaking anti-freeze. When he popped his hood, his engine was hotter than hell and a coolant line popped off. The valet guys took his car for some joy rides.
Old Nov 19, 2010 | 10:11 AM
  #39
tsitalon1's Avatar
This got lost in the traffic:
Old Nov 19, 2010 | 06:10 PM
  #40
Golden's Avatar
There will be 10 total maps. I'm pretty sure you could make one a valet map. Another could be made into a "won't start" type map.
Old Nov 19, 2010 | 08:14 PM
  #41
migs647's Avatar
So how will we know what map we are on? I'm assuming we're using cruise to toggle?
Old Nov 19, 2010 | 08:28 PM
  #42
MicMcKee's Avatar
It's somewhere in this thread or Tephra's other one, the RPMs will bounce to different numbers 0-9k,
Each will correspond to a different map potentially
Old Nov 19, 2010 | 08:31 PM
  #43
tephra's Avatar
yeh - tacho will display what map your on..
Old Nov 19, 2010 | 08:35 PM
  #44
migs647's Avatar
I had a feeling that's what it was going to be, wasn't sure if you had it completely programed yet. Awesome!
Old Nov 20, 2010 | 03:56 AM
  #45
tephra's Avatar
yeh it's done and working...
0rpm = normal maps
1-9 = 8 altmaps
flashing ICS = methsafe map
the good thing now is you can run meth and have 8 altmaps - if you want..
meth overrides everything - so if you have meth on it will run the methsafe maps (unless there is a failsafe event - in which case it will drop to the normal maps)
when meth is off you can toggle around the altmaps...
yeh its pretty awesome
