Ultimate Alt Maps
Old Nov 13, 2010 | 12:45 AM
tephra's Avatar
Ultimate Alt Maps
Ignore the omni4bar version - they will be stripped out in the final version (but I need them for my car )
If you would like any other maps included in the "altmap" now would be a good time to let me know
Just a teaser:
Old Nov 13, 2010 | 01:07 AM
E6-X's Avatar
holy moly ! toooooo many LoL ..... teph da man ! i need a copy of this ! actually, imo only 3 is sufficient.
1 for DD (low boost)
2 for race mode (high boost)
3 for alt fuels/wmi/wi (full race setup)
Old Nov 13, 2010 | 01:41 AM
GST Motorsports's Avatar
Make that gear based and I'm having your children....
- Bryan
Old Nov 13, 2010 | 01:47 AM
tephra's Avatar
yeah....
so you think alt MIVEC maps is a bit of a waste of time?
Old Nov 13, 2010 | 02:11 AM
Originally Posted by tephra
yeah....
I didn't really see a use for it with the 9's but the 10's are a bit of a new beast since they have them on int/ex
- Bryan
Old Nov 13, 2010 | 06:27 AM
tsitalon1's Avatar
Hey Dave, are you going to keep it PSI based as shown? ...say yes.....say yes...
I second the request for gear based Mivec as well...not having your kids though....but it would be entertaining to read how Bryan intends on explaining that one...
Old Nov 13, 2010 | 08:10 AM
mlomker's Avatar
I'm sure they'd have a lovely accent.
Old Nov 13, 2010 | 09:36 AM
blk-majik's Avatar
Nice, cant wait How will you switch between tunes? With just two using the CC button, it's pretty obvious and you always know what map you're running. With 8 maps, it might be easy to lose count
Old Nov 13, 2010 | 11:36 AM
Clipse3GT's Avatar
I also agree. Gear based MIVEC and 1-2 alternative maps is sufficent for 99% of people.
How do you even change 9 maps?
Old Nov 13, 2010 | 12:04 PM
migs647's Avatar
- Bryan
Woah, tephra, please make it gear based so I can see this
I can't believe 9 maps, wow!
Old Nov 13, 2010 | 12:30 PM
Bob_tm's Avatar
No! Mivec can be different for different fuels. Advancing mivec in low loads can increase engine braking, so this setup can be used for race map. With mivec we can smooth power for our boost (for example our taget load is 220, so we set intake mivec to 10 in 240+ load cells). A lot of overlap can work as antilag and this also can be used in race setup!
Old Nov 13, 2010 | 04:17 PM
tephra's Avatar
Hold Cruise ON/OFF the get "into" the map switching mode, and then Cruise Accel/Decel buttons to increment/decrement which map your on.
The tacho displays which map your on, 0 being normal, 1-9 being the 1-9 altmaps...
I have also kept the TPS enable, but obviously you can only increment...
The enable map switching timer is also the disable timer, so once you stop pressing buttons and the timer expires the tacho goes back to normal AND the new altmap gets set.
It's pretty awesome, even if I do say so myself - I am sure someone will put up a nice video of it...
The only problem is remembering what altmap corresponds to what actual map, I think for 3+ altmap users they will need a "cheat sheet" in the car so they remember
Old Nov 13, 2010 | 04:21 PM
tephra's Avatar
ok so on the MIVEC, I still want to work out if a High/Low crossover would be better than full 1/2/3/4/5/6 gear maps..
Obviously its easier to code, but from a usability standpoint I think it also works better...
So for each altmap, there would:
MIVEC Intake #2 High Gear
MIVEC Intake #2 Low Gear
MIVEC Exhaust #2 High Gear
MIVEC Exhaust #2 Low Gear
And then there would be a single generic crossover rpm/mph for ALL the altmap sections to use...
Thats what I will do unless someone gives me a REAL good reason for full gear control...
Old Nov 13, 2010 | 04:48 PM
merlin.oz's Avatar
Dave, I would think what you have outlined in post 13 is all thats needed re MIVEC.
How about a low gear spark map though. The VR4 and Legnum have this and I regularly use it as you can run more advance in the lower gears. Something to think about.
If you want a real blue-sky idea, how about a gear crossover for lean spool, or maybe just a disable in 4th/5th etc. I like lean spool btw, but never leave it at the stock settings.
Old Nov 13, 2010 | 05:32 PM
tephra's Avatar
mmmm I thought about a low gear timing map a while ago, but not sure if it will be that useful...
lean spool sux I have yet to see a good argument for it
And yes I only say that because I haven't been bothered looking into how it works
