Evo 9 GT JDM and Tephra V7
Old Dec 22, 2010 | 11:03 PM
YaroRS's Avatar
Guys, I have Evo 9 GT JDM with rom 89280002, is it possible to use Tephra rom with this ECU, and if possible, wich one should I use.
Can anyone give sent me working XML for 89280002 rom ?
Old Dec 23, 2010 | 05:14 AM
grayw's Avatar
Attached is the xml for 89280002. The JDM GT can be a little odd and does not like running on other JDM rom ID's such as 88570008 etc, you may have better luck on one of the USDM versions.
File Type: zip
Old Dec 23, 2010 | 05:04 PM
Lmodel's Avatar
That's weird..
My 9 JDM GT comes with a Ralliart ECU which has a 89980000 romid. I have been using 88570008 without problems so far. I believe Tephra is in the final stage of the V7 for a few romids and this includes the 88570008.
Old Dec 24, 2010 | 12:20 AM
Danieln's Avatar
seems that the logic mask related to the immobilizer are different between 8928 and 8857.
I think this is the reason that the ECU Roms are not compatible...
Old Dec 24, 2010 | 12:47 AM
donner's Avatar
I have been running my EDM evo 9 with JDM GT ecu with 88840016 and 88580714 ROM's. Only problem so far was in missing EGR control in GT ecu which caused some trouble code related with EGR solenoid (there is not components installed on circuit board to control EGR solenoid in GT ecu). I have not tested yet if disabling EGR from address 103d (8884 and 8858 roms) solves this problem but will do that soon as I will disable EGR anyway.
Old Dec 24, 2010 | 12:51 AM
grayw's Avatar
Originally Posted by Lmodel
That's weird..
Have you tried to run yours on 89280002? The GT is a popular import choice here in the UK. Out of all the ones I've seen, not one will run on 88570008, even with the immobiliser removed, all other model variants work fine.
Even with it disabled it will not start, so it would point to something different in the wiring (like some VII had).
Old Dec 24, 2010 | 01:02 AM
Lmodel's Avatar
I'm located in Singapore but I believed all JDM GT should come from the one and only source, Japan.
Since all JDM GT comes with Ralliart ECU in Singapore, I'm wondering if yours are equipped with the original ECU or the Ralliart version. I've not tried using the 89280002 as there isnt alot of support with this version of romid. The only ones I've tried are 89980000 and 88570008 which seem to be similar to me, even with most of the MUT codes.
See if this link helps.
Old Dec 24, 2010 | 01:22 AM
grayw's Avatar
They come with the OEM ECU and not a Ralliart one here, I can send you the original rom if you'd like to try it (89280002).
Old Dec 25, 2010 | 04:01 AM
YaroRS's Avatar
Thanks a lot for the XML, at least I can see now some maps, any chance you could post a base map for evo 9 ? Because with the one I got, some maps are screwed
Old Dec 25, 2010 | 04:11 AM
grayw's Avatar
Drop me your email addy and I'll send you a standard version of 89280002, it's too large to attach to the post.
Old Feb 13, 2011 | 08:18 AM
YaroRS's Avatar
Guys, can advise me. Trying to run V7 88590715 rom on my JDM 9GT ecu, I turned off all the CELs but I am having real bad throttle hang ? Is there any way to fix it ?
Old Feb 13, 2011 | 08:25 AM
grayw's Avatar
There is a big thread on throttle hang and the fixes available, most common are fuel decel adjustment and stepper motor idle changes. Take it you don't get any hang on the original rom ID?
Old Feb 13, 2011 | 08:37 AM
YaroRS's Avatar
nope, everything is ok, any chance you could me give a link ?
Old Feb 13, 2011 | 08:44 AM
grayw's Avatar
This is the main one Clicky, but if you do a search of threads with throttle hang in the title you will find lots.
Old Oct 26, 2011 | 01:18 PM
YaroRS's Avatar
weird thing about this ROM, I tried to run V7 tephra on it, but it wouldnt calculate fuel correctly, also knock sensor didnt work.
Decided to run original rom.
