having trouble
Old Jan 17, 2011 | 06:01 PM
crckheadjed's Avatar
having trouble
okay this is for an 06 evo, i dowloaded latest ecuflash, drivers for openport 2.0. i open up ecuflash and plug into the obd port, the little jumper and plug into computer. i get no vehicle interface. I assume it is not recognizing the cable??
i have an asus laptop, with windows 7.
This is the only thing that appears in the ecuflash
[20:55:08.995] EcuFlash Version 1.42.2595
[20:55:08.995] OS Version Windows Vista
[20:55:08.995] Qt Version 4.5.0
[20:55:09.025] 56 memory models read.
[20:55:09.025] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[20:55:10.025] 343 ROM metadata models scanned.
[20:55:10.025] checksum module "subarudbw" loaded.
[20:55:10.025] checksum module "mitsucan" loaded.
[20:55:10.025] flashing tool "wrx02" loaded.
[20:55:10.025] flashing tool "wrx04" loaded.
[20:55:10.025] flashing tool "sti04" loaded.
[20:55:10.025] flashing tool "sti05" loaded.
[20:55:10.025] flashing tool "mitsukernel" loaded.
[20:55:10.025] flashing tool "mitsukernelocp" loaded.
[20:55:10.025] flashing tool "mitsubootloader" loaded.
[20:55:10.025] flashing tool "shbootmode" loaded.
[20:55:10.025] flashing tool "shaudmode" loaded.
[20:55:10.025] flashing tool "subarucan" loaded.
[20:55:10.025] flashing tool "mitsucan" loaded.
Old Jan 17, 2011 | 06:05 PM
06RedRalli's Avatar
Mine does this after a long time of not connecting the the car...mine helps if after I plug everything in...then turn the key to acc and it'll pick it up and begin to work...
Old Jan 17, 2011 | 06:15 PM
Just tried again, still nothing
Old Jan 17, 2011 | 07:10 PM
Should my laptop pick up the cable even if its not plugged into the car?
Old Jan 17, 2011 | 07:41 PM
ecktt's Avatar
yes
Old Jan 17, 2011 | 07:47 PM
Okay well thats a start... i plug the tactrix cable into the usb port on my laptop and it does no pick it up or recognize a divice there
Old Jan 17, 2011 | 10:23 PM
drifterific's Avatar
Try uninstalling evoscan and ecuflash and reinstall. That may help, I think that its possible that your drivers did not install correctly.
Old Jan 18, 2011 | 01:52 AM
I tried that multiple times but no luck at all. The USB slots do work too I tried another device.
Old Jan 18, 2011 | 01:56 AM
And from my understanding i let my friend borrow this and he was using this cable for a little while.
Old Jan 18, 2011 | 03:53 AM
Downloaded ecuflash (with drivers) onto my desktop, and still when the USB cable is plugged in with the tactrix box the computer still does not recognize anything and no device is found
Old Jan 18, 2011 | 06:36 AM
siegelracing's Avatar
No devices or an unknown device? Does it make a sound when you plug it in? Do other things work when plugged into that port on your laptop?
Siegel
Old Jan 18, 2011 | 12:24 PM
No device, not even a sound. The usb ports do work with other devices.
Old Jan 18, 2011 | 12:33 PM
Boosted Tuning's Avatar
Go into device manager and add/remove programs and see if any tactrix stuff is installed. If so, manually remove it and uninstall everything and reinstall.
Old Jan 18, 2011 | 02:32 PM
under add/remove prorams 3 driver packages from tactrix, and then ecuflash itself.
Old Jan 18, 2011 | 02:44 PM
Still no luck. Not sure why computers are not picking it up when i plug it in.
