Wierd timing jump: from studder thread: LOG, and IMG of timing map.
Old Mar 10, 2011 | 05:14 PM
  #46
C6C6CH3vo's Avatar
Originally Posted by 211ratsbud
now my fuel is doing the exact same thign out of nowhere! this thing is bogus. nothing has changed in the tune. Piping is all secure.?? puzzled face.
Not sure you can rely on the afr, going from high power afr to 15 - 1 should have a big drop in HP
Old Mar 10, 2011 | 05:18 PM
  #47
211Ratsbud's Avatar
However the knock sum jumps to 5-6 cts fairly quickly though.
Old Mar 10, 2011 | 06:35 PM
  #48
C6C6CH3vo's Avatar
I wouldnt worry about it ruining your engine if thats all you did.
1.8 seconds at stoich would definately create lot's of heat near the ex valves if timing wasnt too advanced, but if thats all you did then it's nothing to loose sleep over. Ive done it before running methano; dry
Old Mar 12, 2011 | 12:01 PM
  #49
211Ratsbud's Avatar
Lol ya know I had to do it a couple times to confirm it wasn't an existing tune problem . wtf, it was a vac line on the manifold > fpr
1999VR-4EVO
Oct 30, 2016 06:58 PM
Midnightevo8
May 6, 2015 10:08 AM
David Buschur
Dec 23, 2010 12:18 PM
