Speed Density 2.0 (3D VE Tables, Baro)
To calculate 10 kPa's equivalent in gauge pressure, you'd have to subtract 14.7 from the PSIa value, which gives you -13.3 PSIg, or approximately -26.6 inHg of vacuum.
Beau
The jitter is known to happen at light throttle, 3krpm cruising load, but it never happened to me. (fix 2 and fix 3 activated)
They're included in V7 SD roms/xmls:
Step 2a: light throttle cruise jitter (this may go away some day)
There is a very small issue with the existing speed density implementation that causes an ever-so-slight jitter while cruising around 2000-2500rpm. The final fix is still up in the air, but for now, I'm recommending mrfred's fix#2 since I've had the best luck with it. The XML is included in the pre-packaged rom, so simply find Fix2 or Fix3 under 'Speed Density Programming' and adjust the values per the mini directions.
- Fix2: change 112 to 0
- Fix3: change 8909 to 0009
Has anyone outside of dtt used his maf formula to build their 3d table? I'm having a problem in evoscan, keeps telling me that load mus be before my ve calc(but it already is).
I had the same problem, Make sure that the Logreference you use in the VE eval is exactly typed like the logreference under your LOAD parameter. The logreference might not be the same as what you see under evoscan on the main screen so you have to go to edit LOAD and look under logreference. Maybe you know this aleady but this is the problem I was having.
Thank you,
Since I have not replaced my maf yet, ( need to make a recirc for my type s) can you use this on a sd rom? Or would it show blank? (To verify function)
Also what behavior should my bov have at idle? My type-s leaks ever so slightly . It vents if you turn the wheel at idle. Should it be completely sealed at idle for best readings? I am fairly certain the metal oem does this as well. I can simply add the second spring.
All the log ref has been changed to my display
You wouldn't want it sucking air at idle as it will be unfiltered, It shouldn't mess anything up tuning wise if your on speed density but not a good idea to suck in unfiltered air.
NVMD it looks like you are going back to maf to do VE calcs? If so you definitly don't want it sucking air as it will throw off your VE calcs at idle.
A leaking bov blows air out not sucks in . For that matter my 80$ buschur maf adapter has two huge holes on each side of the adapter that don't get covered by anything. Lol
I unhooked my wastegate arm, did a pull to redline to check for boost creep. I saw 16.2 lean afr readings at a couple psi. Did that cause my Megan o2 wasn't ported and evidently doesn't need to be. So I thought how and the hell do you get that tuned right? Well.,, I've been wanting to do this for a while. So here I am gonna make a proper attempt!
How sow, there's positive airflow in that space. Hook your boost gauge to your compressor nipple.
Pre tb measurment will typically be atmospheric to slightly positive . Depending on a few variables.
