Speed Density 2.0 (3D VE Tables, Baro)
Old Jul 31, 2013 | 04:26 AM
  #766
211Ratsbud's Avatar
If the rom origin was no map sensor confused as to why they're there(settings you posted), I believed they were just emissions components. What pin should your map sensor be for a rom that had it, and is interchangeable ? In my case the patch was written to read it from a factory location even though it did not exist there oe.
Try running sd perhaps and go for it
Old Jul 31, 2013 | 06:13 AM
  #767
EvocentriK's Avatar
I can get it to run on SD rom, drives ok, had to tweak the 500 Kpa : 680 load in the table to 500:620 to get the AFR/load reasonable. Just haven't tried the PSI based BEC etc yet as I figured without the rom set up to be aware of the GM3bar it wouldn't work. Haven't altered the VE table either since I'm just beginning to understand SD.
It's wired to pin 92, but unsure if it's going to work right.
Old Jul 31, 2013 | 06:54 AM
  #768
90zcrex's Avatar
If its running good on the SD tune and the tune is not far off then the map sensor must be reading.
Old Aug 14, 2013 | 03:28 PM
  #769
211Ratsbud's Avatar
Ok just a quicky here. Made my 3d ve map from maf tossed on the base ve cal, my afr is off by over two whole numbers. Do I correct this in the fuel map or the maf scale to do it correctly?
Old Aug 14, 2013 | 03:32 PM
  #770
domyz's Avatar
If fueling isn't like on MAF tune, you'll agree that load is for sure off. My advice: continue to tweak VE. Many people seem to not land perfectly on MAF tune while doing 3DVE logging.
Old Aug 14, 2013 | 04:16 PM
  #771
211Ratsbud's Avatar
Roger dodger!
Old Aug 15, 2013 | 05:00 AM
  #772
charlie.tunah's Avatar
I think its all relative. As long as the car is getting proper fuel/timing, it should be good. Sounds like you are trying to match MAF loads. Just get your load to line up with your target with VE. Then adjust fueling with the MAF Compensation (or smoothing) if you dont want to alter the fuel map.
FWIW, Id rather not have to rely on hooking a MAF sensor up in the future when I do things that change VE and have never used MAF loads for SD tuning. My current goal is to just get MAP (kPA) to equal load. Then I plan to adjust fueling with the MAF Compensation, while maintaining "real" AFR values in the fuel map. Its not that far off as it sits. But I used to use the VE table for adjusting fueling (not trying to match any load) and there are some areas that need to be tweaked to line it up.
Old Aug 15, 2013 | 07:06 AM
  #773
211Ratsbud's Avatar
, I didn't look at load yet I flashed and did a wot pull and saw 10.0 pegged on the gauge and thought so much for that being close!
Old Aug 20, 2013 | 12:46 PM
  #774
burgers22's Avatar
Just use the MAF load calac to get a running map and then adjust VE table to get fuelling right
Old Oct 12, 2013 | 09:27 PM
  #775
batty200's Avatar
I just wanted to say THANKS! 3D SD is a dream come true. I am going to be playing with this for a while and see if I can get this dialed in on my car so. The VE column was driving me nuts since VE will vary based on turbo efficiency and other factors at higher loads.
Old Oct 12, 2013 | 10:23 PM
  #776
batty200's Avatar
Originally Posted by Dynotech Tuning
The KPA-to-LOAD is controlled by the 3D VE table when you have the 2D KPA-to-LOAD table set at a 1:1 ratio.
Example: If you have a VE of 50% in the 100KPA column, whenever you're at 100kpa, load will be (100KPA*50%= 50 load).
The reason you will see load differ sometimes from what your 3D VE table says it should be is because of other compensations that also affect the calculated load at times. Decel is the most common way to see a huge variance.
Evoscan has a glitch where it claims that one parameter needs to be above another, even though it already is correct. It says it every time I log VE but once I click 'OK', it logs fine.
-Jamie
I just want to clarify that this does not affect where on the fuel map you end up. 100kpa in the VE table only affects 100kpa in the fuel map as well no matter what the "load" is calculated to be, correct?
Old Oct 13, 2013 | 04:05 AM
  #777
211Ratsbud's Avatar
No. Your kpa to load table tells you where you'll be on tephra maps axis at a given kpa . Even at 1:1 it's never truly 1:1 there's load calc variables etc
Old Oct 13, 2013 | 04:09 AM
  #778
211Ratsbud's Avatar
What ever happened to Jamie anyways?
Old Oct 13, 2013 | 07:08 AM
  #779
batty200's Avatar
What item should I log to make sure I am on the proper cell in the SD VE Map? Once I see a variation and I adjust the kpa->load map will it stay on there once dialed or do many other trims affect that as well? I am super excited to dial this in today. Lots of sitting in the car and punching keys! Soo much fun! Hahahaha.
Old Oct 13, 2013 | 08:09 AM
  #780
211Ratsbud's Avatar
Kpa is the 3d ve map x axis.
