Speed Density 2.0 (3D VE Tables, Baro)
OK so now I am out trying to dial in the VE maps.
I have a ported head with a 2.4L 10.5:1 motor with GSC S2 cams and a 6262. How much do you think those items increased VE? I have heard that cams can increase VE by 15% and a ported head can add 5-10%. The increased displacement could theoretically add 17%. This would make a theoretical increase in VE by as much as 40% or more.
I have cranked the SD VE up to 130% and still was running leaner than my fuel maps were calling for. I moved the fuel map from 12.0 to 10.0 and my fuels went exactly to where I would expect with that percent change. Is there an upper limit to the VE effectiveness where I will have to just use the fuel map AFR as an abstract? I can move the fuel map back and add more VE but I don't want to waste time with a limit I am not seeing. I am ok with abstract AFR numbers if needed but I don't want to give up on a LOGICAL fuel map doing what it is called for.
I was wondering if there is a maximum effective amount of multiplier that the VE table can use that I wouldn't run out of range. I don't want to just rescale the injectors even though that would be "easier".
Rescaling the injectors is the correct solution. Sure your 2.4 will look like a 20% VE increase over a 2.0, but it's really a 2.4 so the airflow is relative to that displacement. At the end of the day your maps are going to look much better and you'll have less funniness in all the other tables if you get that first number right.
Good luck!
Good luck!
I don't understand why many people think this is a good idea. Changing the injector scaling messes up the whole map. I have everything working well in vacuum already. The injector size is a not a variable. They are flow tested and the flow is a known quantity. Once injectors are scaled they should be left alone and the rest can be fixed. No other platform promotes this idea. I only adjust injector sizes to compensate for fuel variations because it doesn't change the engine VE.
My question is what is the upper limit for the VE tables in the program? I don't want to run out of resolution on that table and have to do work arounds such as changing injector scaling.
Is there any downside to having the studder fixes turned on? I had a studder at 2k and below that is pretty violent. I don't want to turn them on for no reason if there is a detrimental effect.
As someone said, MAF scaling could sort it out but the easiest way is to rescale the injectors.
