Speed Density 2.0 (3D VE Tables, Baro)
Old Feb 19, 2011 | 12:29 PM
  #31
RoadSpike's Avatar
Didn't find a address="0" in the xml file maybe I am conflicting with some other rom ID i dont know.
Anyways here's two more xml's using inheritance instead of stand alone
File Type: zip
Old Feb 19, 2011 | 12:55 PM
  #32
And's Avatar
And
did you manage to look at the axis? i down loaded it to the car but couldn't get it to start
Old Feb 19, 2011 | 12:58 PM
  #33
RoadSpike's Avatar
hmm I looked at the axis in ecuflash which i thought you meant but didn't see anything wrong.
I'll double check the code maybe the baro code is messing with startup can you log the baro output when trying to start it?
Old Feb 19, 2011 | 01:13 PM
  #34
RoadSpike's Avatar
Think I found an issue I didn't correctly change one of the headers on the rom and it was overriding the ram of another function. This could be why its not starting.
Old Feb 19, 2011 | 01:25 PM
  #35
RoadSpike's Avatar
And check this one out got the headers fixed.
http://www.megaupload.com/?d=BC17BXD8
Old Feb 19, 2011 | 01:30 PM
  #36
element26's Avatar
Got to check this out when i get home
Old Feb 19, 2011 | 08:15 PM
  #37
Creamo3's Avatar
The axis on the 3D table seems to be incorrect for 9653 (see attached)
Old Feb 19, 2011 | 08:27 PM
  #38
philr8's Avatar
Originally Posted by creamo3
the axis on the 3d table seems to be incorrect for 9653 (see attached)
+1
Old Feb 19, 2011 | 08:33 PM
  #39
95630706's Avatar
tried the first 9653 up- no start. I'll try the new rev if I have time tomorrow.
Old Feb 19, 2011 | 08:34 PM
  #40
RoadSpike's Avatar
Ah I see whats going on now I guess i screwed them up when i was merging the 9417 into this rom.
The correct addresses are
379aa - KPA
379fa - RPM
Here's a xml for it
You can correct the axis if you like yourself or just download this xml
File Type: zip
Old Feb 20, 2011 | 12:39 AM
  #41
And's Avatar
And
sweet will try this later, and let you know
Old Feb 20, 2011 | 02:29 AM
  #42
RoadSpike's Avatar
Please log baro when you try it if i screwed up and put the comparision in backwards it probably would effect startups :/
Old Feb 20, 2011 | 06:11 AM
  #43
And's Avatar
And
still couldn't get the car to start, baro was reading 98.8 and omni was readin 99.5 but just kept turning over and not firing
Old Feb 20, 2011 | 10:41 AM
  #44
golruss's Avatar
I got a failure trying to load the bin file (tried 3 times) loaded up my current bin and started right up. Did not capture the error message.
thanks
Old Feb 20, 2011 | 12:10 PM
  #45
RoadSpike's Avatar
Alright give me awhile I'll find out what the hell is going on. I imagine its probably something simple that happened to it.
