Speed Density 2.0 (3D VE Tables, Baro)
Old Jun 18, 2021 | 02:26 AM
  #991
mines5's Avatar
Originally Posted by SnailSpeed
Thats the one i'm using. Gonna try disabling the immobilizer, confirm leaving ecu internal id alone?
I left ECU internal ID as is.worked for me.
Old Jun 19, 2021 | 06:00 AM
  #992
SnailSpeed's Avatar
Car started with immobilizer disabled. I hate to leave it disabled tho. Thanks again mines!
Old Mar 20, 2022 | 06:21 PM
  #993
CRONZ305's Avatar
I have the GM IAT that i picked up from spoolinup but noticed the scaling he has listed doesnt match the SD 2.0 SD MAT Scaling for IAT Scaling Table. Is this a big issue?
https://www.spoolinup.com/GM-IAT-Sensor_p_30.html
File Type: xlsx
Old Aug 22, 2022 | 02:18 PM
  #994
unkn0wn.'s Avatar
Originally Posted by mrfred
An OEM MAP sensor is used. It requires a special SD patch that has not ever been widely distributed. If you drive at varied altitudes, it would be a good thing to have for offboost drivability where idle can be affected by barometric pressure.
Sorry to bring this back from the dead but my hunt for this elusive 2D SD active baro patch for the spoolinup mrfred harness is what lead me to this post. If anyone has seen it linked somewhere & can point me in the right direction I'd appreciate it, otherwise my hunt continues.
Old Apr 8, 2023 | 09:32 AM
  #995
ASEvoIXSE's Avatar
I patched this rom with the flex fuel patch see my post Tephra v7 SD2 Flex Fuel ROM
Old Apr 8, 2023 | 04:12 PM
  #996
ASEvoIXSE's Avatar
Look at this post, download the rom, i think the patch exists in the ver2 of the rom containe in this zip. It also includes DMA with SD2.
https://www.evolutionm.net/forums/ec...l#post11641135
Copy all the XML's to your ecuflash metadata folder. Then load the roms.
ver2 (88586714-TephraMod_ver2) includes SD2 with smaller 3D VE table to allow DMA to be patched in.
The non ver2 rom (88582714-TephraMod) has just the SD Bar ADFC and DMA patch, no SD2.
Im gonna try to patch flex fuel to it as sell. Specifically the DS2 + DMA ver2 rom.
Old Apr 10, 2023 | 02:19 AM
  #997
Rovin's Avatar
I still wonder till today. Why no one is implementing all this to fully Speed Density Rom (Map sensor based) there is already a lancer ROM based on Map Sensor fully.
Rom ID 93270019 Bin file from 1.6 lancer. i saw a russian guy mod the whole file to be used on Evo 7
tephra
Apr 22, 2026 11:03 AM
tephra
Apr 23, 2014 07:45 AM
ClixT
Lancer Engine Management / Tuning Forums
Nov 14, 2010 10:06 PM
defx2
Apr 9, 2009 02:23 AM
