Speed Density 2.0 (3D VE Tables, Baro)
Old Feb 19, 2013 | 01:43 PM
  #616
Dynotech Tuning's Avatar
AEM has no load variable. It's just KPA/IAT/CTS and RPM. It also has no VE table since you just change the fuel map until you get it dialed in to hit your target AFR. Since the stock ECU is based off a LOAD calculated system, it's riddled with load tables so much that its much easier to create a VE Table to help convert KPA to load.
The SRT-4's are a load based SD system with a VE table similar to how our ECU patch was created. AEM simply bypassed the load variable.
-Jamie
Old Feb 19, 2013 | 02:02 PM
  #617
211Ratsbud's Avatar
-Jamie
I was wondering if we could have kpa on our load axis and just use iat ign trims and such. But you said riddled.. Lol
I'm looking forward to a ms3 pro unit
Old Feb 19, 2013 | 02:31 PM
  #618
99EclipseGSX's Avatar
Originally Posted by 10isace
I'm using Omni 4 Bar.
I've never used another SD system, but I'm looking forward to trying one. Is AEM's a true SD?
Like Jamie said, the AEM Series I/II isn't "true" SD, it's more of a fuel pulsewidth lookup table. However, the new Infinity EMS which I'm running on my race car is a true VE airflow based model, and is pretty incredible. One big advantage of true SD is the lack of tuning time considering the fact it's a standalone. You fill in injector size, displacement, sensor data and the engine starts up and runs even with a "guess" of 70% VE in the whole map. If you're lucky like me and already have a VE map from a previous ECU (ECMLink V3 SD) then you just drop it in and have the thing dialed in literally minutes. But I digress.
Beau
Old Feb 19, 2013 | 04:14 PM
  #619
I never called v1/v2 a true SD. It's not as you pointed out. I thought you were saying it was which I why I posted.
Old Feb 19, 2013 | 04:34 PM
  #620
Sorry, worded my last post incorrectly, fixed that now. Didn't mean to sound like I was arguing!
Beau
Old Feb 22, 2013 | 12:56 AM
  #621
Mr.Nik's Avatar
Who set up this firmware ID1000
What values ​​installed
Injector Scaling - ?
Injector Latency - ?
Please share!
Old Feb 22, 2013 | 01:42 AM
  #622
Biggy VIII's Avatar
Please share!
see attachment below..
however scaling may vary from 812 to 860, so may latency, but just a bit, depending on your setup.
Old Feb 22, 2013 | 09:10 AM
  #623
10isace's Avatar
Originally Posted by evo8426
Attached is what I use on several SD cars including my own for the map sensor and kpa to load.
To use fuel temp all I had to change was the 0x0E
Which map sensor are you using? I'm using the Omni 4 bar and my settings aren't working. Also which ROM are you on?
Thanks!
Old Feb 22, 2013 | 10:56 PM
  #624
tjac357's Avatar
Quick question. Setting my car up on SD 2.0 and it likes getting really rich when I give it any throttle. Since my kpa to load is 1:1 when I'm at 100 load I'm at 100 kpa correct?
Also, does anyone have the evoscan formula for logging kpa? Reading through a whole bunch of stuff, but can't seem to find it. Thanks. 8859 Rom
Old Feb 23, 2013 | 08:07 AM
  #625
10isace's Avatar
Here you go: https://www.evolutionm.net/forums/10653198-post75.html
Old Feb 24, 2013 | 01:52 AM
  #626
Biggy VIII's Avatar
It seems that I could solve my previous problems just switching from 9653 to 9417 rom. 3D SD works, the car generally feels the same as it was on MAF. I have made some logging on my MAF tune before trying SD and made a calculated VE table that brought me in the ball park. However a small jitter exists at 2-2,5K cruising. Jitter fix #1 made some difference, but haven't fully cured it.
The new problem that I have now is warm starts. Drive the car, shut it down, come back in 10 minutes and try to start it up - the car starts and dies immediately. If I catch it with throttle, it will hold the higher revs, but seems to be a bit lean. Sounds like IAT heatsoak?
It happened half way from work back home so I didnt have enough time to explore that problem, just have to drive back home. It drove fine and idled fine after a short run on the street.
If I shut it down and start it in less than 5 minutes or more than 20-30 minutes it behaves well and seems to have nop problems at idle except its a bit rich (13-ish)..
Has anyone experienced the similar problem?
Old Feb 24, 2013 | 06:40 AM
  #627
evo8426's Avatar
Thanks!
I use the Mitsu 3 bar on my car and use the 8859 ROM. I do have settings for the Omni on another computer and can send your way later today.
Old Feb 24, 2013 | 05:17 PM
  #628
tjac357's Avatar
Thanks a ton! This made my weekend so much easier. Couldn't get VE to log though since it was say Load1Byte needed to be above VE for it to work and it was.
It's weird that while my kpa and load are close sometimes one is higher than the other and vise versa for no reason and my kpa to load table is 1:1. Not an issue, just an observation.
Old Feb 24, 2013 | 05:24 PM
  #629
The KPA-to-LOAD is controlled by the 3D VE table when you have the 2D KPA-to-LOAD table set at a 1:1 ratio.
Example: If you have a VE of 50% in the 100KPA column, whenever you're at 100kpa, load will be (100KPA*50%= 50 load).
The reason you will see load differ sometimes from what your 3D VE table says it should be is because of other compensations that also affect the calculated load at times. Decel is the most common way to see a huge variance.
Evoscan has a glitch where it claims that one parameter needs to be above another, even though it already is correct. It says it every time I log VE but once I click 'OK', it logs fine.
-Jamie
Old Feb 24, 2013 | 05:33 PM
  #630
To first confirm its heatsoak and not the startup tables that need attention, you need to log the IAT readings to confirm its truly heatsoaking before you start the car under the conditions you mentioned.
-Jamie
