Speed Density 2.0 (3D VE Tables, Baro)
Old Feb 15, 2013 | 03:16 PM
  #586
Architechnik's Avatar
Well, they should be 1:1, but it's actually used for as a scaler to figure out what kind of load is comparable to a particular voltage for your sensor input. This means if you put the peak at 500 when it should be 370, you're telling the ECU that at 3.5 bar, it should be a load well below the 350 peak.
If I've done my calcs correctly, I think if you've changed the settings like you have, then you would read a load around 148 at 2 bar. What do you see for load at idle?
10isace, I don't have the VE Calibration window you're showing. You may have a later version?
Old Feb 15, 2013 | 03:32 PM
  #587
10isace's Avatar
If I'm understanding you correctly, you're saying that both of them should be 1:1. I tried to do that. This is what happens to the Map Sensor KPA:
I don't see idle on this ROM. It I have to modulate the throttle to keep it from dying. It's incredibly lean around 21 AFR.
BTW, I tried your Excel sheet and it looks good. That's fairly close to what I came up with after logging VE for a couple of days on MAF.
The Calibration table is carried over from the 2D SD ROM.
Old Feb 15, 2013 | 03:36 PM
  #588
I'm glad the spreadsheet came in handy. I wasn't talking about those two tables being 1:1, though. Like I said, I don't have the VE and Calibration Table.
The Map to kPa and kPa to Load should both be 1:1 after setting the correct sensor in the Map to kPa settings (ctrl+m). I'm guessing the calibration table is really just the output of the calcs done by setting the other tables.
Old Feb 15, 2013 | 03:45 PM
  #589
10isace's Avatar
I also noticed the 9653 SD 2.0 doesn't carry over the old SD ROM. Is that right? The xml for 2.0 says to inherit the TephraMod-96530706-v7.
The 914172715 ROM inherits the TephraMod-914171715-v7 ROM and that ROM inherits the TephraMOD-94170715-v7.
Old Feb 15, 2013 | 03:49 PM
  #590
10isace's Avatar
Yeah, they're 1:1.
Are you running the 9417 SD 2.0 ROM? Are you not inheriting the 2D 9417 ROM? Care to post up your XMLs for both?
Old Feb 15, 2013 | 03:57 PM
  #591
I'm actually running the 9653 on a 1g DSM. The 9417 doesn't have the right trigger sequence for the crank sensor, while the 9653 has the same trigger sequence as the 1ga CAS combined unit. Other than that, they should be nearly identical.
If you're having trouble getting it to recognize the right XML, try copying just the files you want to use to a different directory and then change the location settings in ECUFlash. That should force it to use the correct definition, assuming there is one specific to that ROM.
Old Feb 15, 2013 | 04:34 PM
  #592
Dynotech Tuning's Avatar
The the values in the left and right columns aren't the SAME number, you aren't setting things to 1:1 like I had suggested earlier.
Old Feb 15, 2013 | 04:38 PM
  #593
The first one posted was correct: http://i198.photobucket.com/albums/a...ps927d0117.png
Old Feb 16, 2013 | 03:51 AM
  #594
Biggy VIII's Avatar
Originally Posted by Biggy VIII
OH! I feel much better now, as I'm not the only one with that problem!!!
I'm definately going to try 9417 SD 2.0 rom. So I have several questions, hope somebody can answer me:
- If I want to use Fuel Temp pin as MAT input, I put 0x03 in "SD Convert IAT to MAT (0x03 -> 0x0E)" ? Should I make any other changes?
- Do I need to make any changes in "MAP sensor" section of the rom? I have EDM Evo 8 that doesnt have MAP sensor in stock...
Anyone?
Attached Thumbnails Speed Density 2.0 (3D VE Tables, Baro)-map-sensor-section.jpg
Old Feb 16, 2013 | 09:51 AM
  #595
CDrinkH2O's Avatar
Originally Posted by 10isace
No problem.
What happens if you open a the 94170715 MAF version?
Just sent it. Do you need the Bin file too?
I've just been through the 94170715 and 94172715 XML files you sent me and they are identical to mine. This points to either; a bug in the binary TephraMOD-94172715.bin that we both downloaded and used, or a problem with our understanding of how to set it up.
I'm not making any progress with either of the 3D ROM's (96534706 or 94172715) at this point and without further input from the community I don't have the time to use trial and error to figure out what I'm doing wrong. Both 96534706 and 94172715 ROMS go lean on tip in on my 2005 USDM VIII and don't seem to respond to tuning 3D VE.
Can anyone suggest how to troubleshoot this step by step please?
Old Feb 16, 2013 | 09:56 AM
  #596
CDrinkH2O's Avatar
There may not be many people running 94172715 (3D SD) on the EDM Evo 8 so you may be the first to try this.
Old Feb 16, 2013 | 10:04 AM
  #597
evo8426's Avatar
Attached is what I use on several SD cars including my own for the map sensor and kpa to load.
To use fuel temp all I had to change was the 0x0E
Attached Thumbnails Speed Density 2.0 (3D VE Tables, Baro)-kpa-load-settings.jpg
Old Feb 16, 2013 | 10:12 AM
  #598
CDrinkH2O's Avatar
Originally Posted by 99EclipseGSX
Using your scaling values seemed to help with one issue, but this patch still is giving me lots of load problems. It's reporting way too low of a load at all times, even with high VE values. As a test I put 100% VE in the table at anything above idle, and I hit 14 psi and load still only reported a max of 115, where of course since kPa to Load is set 1:1, and so is Map Sensor kPa, so I should be seeing closer to 190 load at that boost level (approx 190 kPa boost).
I'm also having to use WAY too low of an injector scaling value to get the car to about where it should be fuel trims wise at light load. Typical Actual engine VE will typically be below 60% at idle, and there's no way I'd be able to get the car to run down there. It runs perfect with the older 31706 2D SD stuff.
This is why I usually stick to standalones.. It's fun playing with patches though but I really don't like skewing/bandaiding data to get the car to run properly. I should be able to input an accurate injector scaling value, accurate MAP sensor data, and realistic VE values and have the load match actual load (kPa) and have actual AFR match target AFR.
Beau
Same here. I've now tried 96534706 and 94172715 with similar issues - load doesn't increase 1:1 with increasing kPa, and increasing 3D VE values has little effect. This points to either a fundamental bug or difference in the binaries we are donwloading compared to Jamie, or a basic flaw in our understanding of how to set up and tune the 3D SD ROMs.
JAMIE - Can you share the base binaries you are using for 96534706 and 94172715 so I can compare (filediff) them with the ones we are downloading from post #1?
Old Feb 16, 2013 | 11:00 AM
  #599
CDrinkH2O's Avatar
Yes. In the XMLs I have 96534706 inherits 96530706
No. 94172715 (3D SD) inherits 94170715 (base ROM). My 94172715 & 94170715 XML files (which are identical to the ones you sent me) show this. I think you may have screwed up your XML file inheritence from what see on your screen shots
Old Feb 16, 2013 | 11:02 AM
  #600
Biggy VIII's Avatar
- nevermind.
