Serial to usb pointer goes everywhere
Old Feb 25, 2011 | 11:35 AM
Stradag's Avatar
I could not find this issue discussed anywhere so I figured I would post this in case anyone runs into this issue.
If you are using a serial o usb adapter and sometimes your mouse pointer goes everywhere when you have your adapter plugged in, it is probably because windows thinks your zeitronix or whatever your using to log is a serial mouse due to the serial input.
How do you fix it?
Windows XP
Go to control panel>system>Hardware Tab>Device Manager>expand the mice and other pointers section
Find the device that says serial mouse right click it and hit disable
Windows Vista
start --> run --> "regedit" --> HKEY_LOCAL_MACHINE --> SYSTEM --> CurrentControlSet
--> services --> sermouse --> Double click "Start" (on the right side of the tree) --> replace 3 with 4 --> [OK] --> restart Done!
Old Feb 25, 2011 | 11:38 AM
RoadSpike's Avatar
Your computer believes that the device is a mouse and the communication of the zeitronix is doing this. What I've found with mine was start the computer up with the zeitronix unplugged and plug in the serial usb converter in. Then once the usb drivers fire up i could plug in the zeitronix and start up the car.
Seems if there is no communication going on when you plug the usb thing in it works fine.
Old Feb 25, 2011 | 12:12 PM
Stradag's Avatar
You are correct, I just figured if people would like to rid of the problem this is how you do it
Old Feb 25, 2011 | 01:28 PM
Boosted Tuning's Avatar
+1, thats how I get mine not the do the jumpy mouse pointer thing.
Ill try your fix when I have time and see if it works for me.
Evorange
Sep 16, 2019 08:18 PM
bustin
Mar 18, 2018 05:44 PM
parralegend
Feb 18, 2013 02:35 PM
211Ratsbud
Oct 29, 2012 10:31 PM
vboy425
Oct 9, 2009 04:40 AM
