Speed Density Help
Old Mar 1, 2011 | 03:49 PM
  #31
RoadSpike's Avatar
BTW I just noticed your playing the Maf scaling instead of smoothing thats not good :P
I think they call the table in your rom maf compensation and its scaling should be in percentage 128.
Old Mar 1, 2011 | 04:15 PM
  #32
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
ok so adjust load not kPa but that makes it richer which is the problem. and roadspike i am on 88591715 the ix rom, do u have a 3d rom for that rom??
Old Mar 1, 2011 | 04:27 PM
  #33
Creamo3's Avatar
Increasing load makes it richer and decreasing leaner. If your STFT are + for a specific area you'll either want to decrease load or decrease RPM VE. If your STFT are - then you'll want to increase those areas. Same thing applies for RPM VE
Have you read this thread on setting it up?:https://www.evolutionm.net/forums/ec...ched-roms.html
Old Mar 1, 2011 | 04:33 PM
  #34
RoadSpike's Avatar
Not yet thats coming out soon.
Old Mar 1, 2011 | 04:59 PM
  #35
yeah i read that i just was unclear about the map vs ve table
well i guess i'll have to wait when it comes out i'll most definitely try it!
Old Mar 2, 2011 | 01:18 AM
  #36
RoadSpike's Avatar
Sent you an email with the rom if you want to try it. It like the others excepts you have the xmls from the other tephra roms.
Old Mar 2, 2011 | 06:58 AM
  #37
to no clutter ur sd 2.0 thread i'll ask this here. Which i think from skimming that tread i am right.
i have to change just the scaling for map sensor kPa table (omni4bar to klavico 3.5bar), and that will make the map sensor kPa scaling correct for kPa to load and 3d tables? Then after changing the scaling i should make the map volts side 1:1 with the kPa side for the map sensor kPa table?
Old Mar 2, 2011 | 08:57 AM
  #38
RoadSpike's Avatar
Yep thats exactly how it should be done
Old Mar 2, 2011 | 10:37 AM
  #39
well did that and it was so rich i could barely drive it out of its parking spot. so should i mess with the left side of the map sensor kPa table
Old Mar 2, 2011 | 10:43 AM
  #40
RoadSpike's Avatar
Indeed you should thats why its there lol
Old Mar 2, 2011 | 10:48 AM
  #41
don't mock me i am just finally starting to get this
so after i get it close to what the afr it should be then does the fine tunning happen in the 3d table?
also should load be logged in 1byte or 2byte??
Old Mar 2, 2011 | 11:00 AM
  #42
RoadSpike's Avatar
Awww what fun is that i can't even mock my test people now
Its a tephra rom so 1byte only I don't think 2byte is setup at all.
Old Mar 2, 2011 | 11:04 AM
  #43
it is when u mess with the mut tables, so should i stick to 1 or 2 byte? if tephra has it as 1 by default i will assume 1
Old Mar 2, 2011 | 11:13 AM
  #44
RoadSpike's Avatar
I would have left the mut tables alone and used 1byte to log
Old Mar 2, 2011 | 11:29 AM
  #45
ok then i'll go back to 1 byte
