Speed Density Help
Old Mar 3, 2011 | 11:04 AM
  #61
RoadSpike's Avatar
Originally Posted by Skylineracer
ok that makes good sense, how about the baro kPa table when would i mess with that? or i shouldn't lol
Shouldn't really need any adjustment unless you live near space :P
Old Mar 3, 2011 | 11:23 AM
  #62
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
i think my biggest issue is i don't under stand the math thats going on. and i also don't understand why almost everyones tables are so close to being 1:1 where mine are radically off from that no matter which right or wrong table i am adjusting.
Old Mar 3, 2011 | 11:26 AM
  #63
RoadSpike's Avatar
What math? Its a table this kpa == that load.
Even at idle your at some kPA pressure and if its rich its too much load.
Load == fuel
Old Mar 3, 2011 | 11:28 AM
  #64
Load == fuel
thats how i understood it but i get confused as to why my tables end up so far from 1:1 to get it anywhere near a normal AFR
Old Mar 3, 2011 | 11:37 AM
  #65
RoadSpike's Avatar
The table itself is like a broad adjustment to the fueling while the 3d table is like a fine tune for the fueling. In a sense you could be 1:1 and tune out the difference with the VE table but I prefer using the 2d table to get close and then fine tunning.
My 2d table numbers were never 1:1 either. I found in the vacuum portion i was always less load than kPa and in the boost section it was more load than kPA. I'm sure if i had this nice 3d table I could have made it 1:1 but it would have been like 65-70% at idle and over 125% during boost
Old Mar 3, 2011 | 11:52 AM
  #66
0 0
10 10
20 20
40 40
60 60
80 80
100 100
500 680
is what the kPa vs Load looks like
so that means that from 0-100 its all vacuum? because the way i see it 101kPa is 14.7 which is when we negate atmospheric pressure and go into boost. do all the 0-100 load values will be lower to lean out the mixture under vacuum?
Old Mar 3, 2011 | 12:02 PM
  #67
RoadSpike's Avatar
0 0
10 10
20 20
40 40
60 60
80 80
100 100
500 680
Yep 0-100 is all vacuum with 100kPA being 0psi or 14.7psi(A). That (a) is important as it means absolute pressure with 0 being perfect vacuum.
I have an older map of my car i can show you how my kpa vs load looked like. You should be able to tell vacuum settings took some work. lol
KPA
47.6424
59.044
72.8888
80.6256
94.8776
110.351
234.954
500.000
Load:
40.0438
50.0081
72.0787
100.016
306.009
687.542
Old Mar 3, 2011 | 12:05 PM
  #68
l2r99gst's Avatar
I never had a 1:1 relationship either. It's just not 'right'. But, you can choose whatever you want, as mentioned, and use the 3D VE table to fine tune.
Old Mar 3, 2011 | 05:22 PM
  #69
new update, car idles, and drives pretty good under vacuum except it still has problems with tip in going lean. also when going into boost it shoots really rich i guess lowering the load on the boost kPa should help.
Old Mar 3, 2011 | 05:56 PM
  #70
RoadSpike's Avatar
When your getting lean tip in pay attention to the kPA,load, and rpm its at. You may need to adjust the async tables or adjust those respective lower load VE points to tune out the tip in.
Old Mar 3, 2011 | 06:17 PM
  #71
gotta be async cause i have the table tuned to take care of rich at the same loads and rpm as the lean
Old Mar 3, 2011 | 06:26 PM
  #72
RoadSpike's Avatar
Looks like your making progress now though
Old Mar 3, 2011 | 06:29 PM
  #73
finally
Old Mar 3, 2011 | 06:33 PM
  #74
tscompusa2's Avatar
when i had that issue with a customer car i just forced it into open loop mode and adjusted the cells and fixed it .. it kind of felt like a hack job to me but it worked..
if you fix it without doing that please update so we know how to do it. when i tried to correct it with async tables it didnt work.
kudos to roadspike for helping you so much.. hes a very helpful and knowledgeable guy for sure. where is his EvomGuru badge already? lol
Old Mar 3, 2011 | 07:21 PM
  #75
i agree on the guru badge, if i could send a beer over the interwebs i would!
