Cams and lopiness???
Old Mar 13, 2011 | 12:42 PM
EriCS's Avatar
Hey, I have been reading up on how to make cams lopier or less lopey. I currently have S2's and I would like the car to sound like they have cams. Mellon did a great job on smoothing them out but I am playing around trying to get them to sound more lopey. I have Mivec and played with advancing the intake cam at idle but I don't know how advance to make it. I have a 3* right now and it seems to have gotten bit more lopey but am afraid to advance it more. I also played with the timing at idle by decreasing and incresing timing. I really don't think this helped much but just made it idle poorly by causing the car to stumble at idle as opposed to being lopey. Whats the most i want to advance the mivec intake cam and any other suggestions???
Old Mar 13, 2011 | 12:53 PM
Raptord's Avatar
You should be able to add more MIVEC advance without any trouble. Try 7-10° of intake advance
Old Mar 13, 2011 | 01:02 PM
erald01's Avatar
Isnt 7 degree going to smooth it out?? I thought 5 degree at idle is the oem setting??
Old Mar 13, 2011 | 01:05 PM
EriCS's Avatar
I believe ignition timing smoothes it out when raised not mivec.
Old Mar 13, 2011 | 01:09 PM
erald01's Avatar
got it makes sense
Old Mar 13, 2011 | 01:24 PM
EriCS's Avatar
Okay I added some timing on the intake cam (mivec) to 7* and it got just where I wanted it! Thanks...
Old Mar 14, 2011 | 12:14 PM
b16a2delsol's Avatar
I had mine at 16 * and it sounds awesome, but you might end up throwing codes lol
The weird noise I make was because I almost fell over lol
http://www.youtube.com/watch?v=0UTDPhYj-1c
Old Mar 14, 2011 | 01:23 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Your trying to have your car sound like mine buddy?
Old Mar 14, 2011 | 07:21 PM
Tonba's Avatar
How would you smooth out the lope on a E8?
Old Mar 14, 2011 | 07:31 PM
tscompusa2's Avatar
raise the idle rpm and timing and it will remove the lope.. want the lope? then lower the target rpm as low as it can be stable. around 750-850rpm. it can be done with mivec also like raptord pointed out.
if you use the biss to lower the RPM, be sure to freeze the idle air controller so you dont throw its calibration off when adjusting the idle set screw via the speed adjustment screw (SAS actuator) in evoscan.
Old Mar 14, 2011 | 07:34 PM
Raptord's Avatar
x1000 on this, you do NOT want to screw around (pun not intended) with the BISS without the SAS actuator being activated.
Piro Fyre
10
Jul 9, 2020 12:22 AM
ethan169
Mar 23, 2010 05:43 AM
Shacochis06
Jun 16, 2008 02:06 PM
EvoAnthony
May 14, 2007 04:25 PM
bogey8
Jun 23, 2006 04:52 PM
