Tephra V7 96530706 IC Control
Old Apr 14, 2011 | 09:26 PM
  #31
widge's Avatar
Ok well the scaling must be correct its set to the same scaling as the 9626009.xml anyway
So it must be something else..
Old Apr 14, 2011 | 09:28 PM
  #32
tephra's Avatar
I wonder if there is a periphey bit to control auto-ics...
bear with me
Old Apr 14, 2011 | 09:30 PM
  #33
tephra's Avatar
not as far as I can tell..
you didn't touch the timers at all did you?
Old Apr 14, 2011 | 09:37 PM
  #34
widge's Avatar
Yeh i changed the On Timer to 3 seconds and off timer to 0.5 seconds
Old Apr 14, 2011 | 09:38 PM
  #35
tephra's Avatar
maybe start fresh and ONLY change the ECT+TPS parameters
i dont know how the timers work
Old Apr 14, 2011 | 09:40 PM
  #36
widge's Avatar
Ok will do,
So i can change all other parameters to get it to spray for me but leave the timers stock?
ill try that over the weekend and report back
  #37
tephra's Avatar
just change the bare minimum to get it to work
ie leave speed alone, etc
Old Apr 14, 2011 | 09:45 PM
  #38
widge's Avatar
Yeh now worries will do ill change the ECT, TPS and Load
Leave the rest stock and will report back
Old Apr 14, 2011 | 09:50 PM
  #39
widge's Avatar
One other thing i can think of is if the MAX Vehicle Speed is incorrectly named and it should be MIN Vehicle speed??
Old Apr 20, 2011 | 04:11 PM
  #40
widge's Avatar
Ok so everything was stock other then the items to get it to spray when i rev it to see if its spraying
Nothing this is still not spraying, do you think the MAX Vehicle Speed is actually Min Vehicle Speed?
Old Apr 20, 2011 | 04:33 PM
  #41
widge's Avatar
I will Pay you tephra to resolve this issue, PM what its worth,
Thanks mate
Old Apr 22, 2011 | 09:01 PM
  #42
C6C6CH3vo's Avatar
My 94170715 has a IC Relay Timer On/Off Time @ 247e. It's wrong.
Original had a IC Relay Timer time @ 248a. Changing it to 8a will let you correctly program on/off for the relay in my car.
Found out the hard way. That relay controls compressor pressure via DV in my car per TPS100% application. Had it set to 10 yet after 2 seconds the DV would open (middle of 2nd gr) and boost would drop. Didn't pinpoint it until I was messing with the NLTS for fun at 2000rpm and would hear the damn relay enrgize after 2 sec
Old Apr 23, 2011 | 05:27 PM
  #43
widge's Avatar
Mine is already defined to 8a
Old Apr 26, 2011 | 03:46 PM
  #44
widge's Avatar
I think i have a work around for this, well for me anyway
What i have done is set my ICS Spray on Knock (because this works), to spray on 0 Knock Sum Above 200load as this is when i want it to spray anyway, so for now this will do
Thanks
Old Aug 26, 2014 | 09:03 PM
  #45
92LaserRs's Avatar
SO i know this thread is old but its something i have recently started to try to get working on my DSM.
The guide mentioned in this thread can be found here:
http://www.mrtperformance.com.au/ima...IX-ICSpray.pdf
One key point I noticed in this write up was that the switch needed to be in the AUTO mode. Going to see if this is my issue on the dsm as i couldnt get it to trigger earlier.
