Tephra V7 96530706 IC Control
Old Mar 2, 2015 | 03:19 PM
  #46
pitbulllove2003's Avatar
does anyone know what the table locations for the 94170008 id my options in ecu flash for ic relay timer on/off, ic relay control min rpm, ic relay control water temp, ic relay control min load, ic relay control TPS position, ic relay control min air temp are greyed out and unusable at the moment ... th reason I need them is I swapped to an air to water intercooler and want the ecu to control the water pump for said modifacitation and is already tied in where the sprayer pump would be plugged in at so I just need those options opened up to me in ecu flash n I can figure the rest out from there
Old Mar 9, 2015 | 11:26 AM
  #47
hello
just wondering if the guru's can help me / point me in the right direction I tried to PM tephra but he cant accept any new private messages so I will try to go this way
my problem is the following is grey / not available for me to change the settings of in ecu flash
my internal Id: 94170008
1. IC relay timer on/off
2. IC relay control min rpm
3. IC relay control water temp
4. IC relay control min load
5. IC relay control TPS position
6. IC relay control min air temp
I have found posts about this but they are all for different internal id's not for the one I have witch is 94170008
willing to pay for help if my issue can be resolved so just message me back if any of you guys can help me out
Old Mar 12, 2015 | 09:15 AM
  #48
still searching for help
still searching for help please if anyone can tell me all the table n locations for the intercooler sprayer functions for ecu flash for the 94170008 rom id
Old Apr 2, 2015 | 09:36 AM
  #49
still searching for help with above list definitions ... can anyone help
Fireescape
Mar 26, 2016 05:19 PM
axxevo8
Nov 22, 2015 08:20 AM
steven121
Feb 9, 2013 08:16 PM
stunt2
Mar 12, 2011 02:41 PM
03whitegsr
Oct 17, 2009 10:20 PM
