Locked out from changing Injector Scaling in ECUFlash
Old Apr 2, 2011 | 03:08 PM
SEEnoEVO's Avatar
I have tried this on two different computers and am getting very frustrated. I am currently running the 96530006 with the Tephra V5.10 mods. I am set as developer and have done plenty in ECUFlash to feel like I know what I am doing. In the past I have scaled the injectors and monitored the STFT and LTFT and made modifications to my tune. It has been a while so maybe I am just messed up somewhere. That...or maybe I need an older version which I cannot find to download. I am able to change EVERY other variable in the map EXCEPT the injector scaling which is what I need to adjust for the displacement change of the new motor. PLEASE HELP!!!
Old Apr 2, 2011 | 03:28 PM
SEEnoEVO's Avatar
I can use the direct method "0x..." but the number doesn't make sense. When I do 0x555 it's comes up with 2459 or somewhere in there.
Old Apr 2, 2011 | 03:52 PM
SEEnoEVO's Avatar
Found Older versions....still not working. Its like the address or something may be incorrect. I dont get it.
Old Apr 2, 2011 | 04:16 PM
SEEnoEVO's Avatar
May just jump to V7 since I can get that to work fine. Only thing I noticed is the MUT table has a few different addresses in it in comparison to my V5.10. It's only like the first few but with a new build I just don't want any other issues when trying to fire it up.
Old Apr 2, 2011 | 04:17 PM
SEEnoEVO's Avatar
Can someone else look at my rom and see if they can change it?
Old Apr 2, 2011 | 06:14 PM
SEEnoEVO's Avatar
Delete. The MidwestEvos forum helped me out. Thanks!!
Old Dec 23, 2011 | 02:57 PM
Carloverx's Avatar
what was the answer...?
Old Dec 24, 2011 | 11:58 AM
grim~'s Avatar
i need to know too,i cant use the [ or ] to change values i have to manually enter a value in and even then if i put 1200 it goes to like 1280
Old Jun 16, 2014 | 10:00 AM
hutch959's Avatar
exact same issue...
anybody???
never mind.. .figured out.
Old Jun 16, 2014 | 12:05 PM
Ev0ikon's Avatar
There are two types of people in the word - those that could read HEX and those that couldn't. :}
Old Jun 17, 2014 | 10:57 AM
jrainwater's Avatar
Well the way I understand it is there are already arbitrary values that you have to choose from and then have to find the latency numbers for that particular scaling. I have FIC 1100 high z injectors and a lot of guys scale those @ 943, where my car runs great with them scaled @ 975 (the next bump up from 943) on 93 octane.
Old Jul 5, 2014 | 04:07 AM
3gturbo's Avatar
Your usermode most likely is set wrong. I set mine to developer in ecuflash.
Old Jul 5, 2014 | 04:50 PM
BadassEvo8's Avatar
Do you have the crappy beta version they came out with? I can't seem to even get it to work but when I do Ecu Flash always sh*ts itself. Maybe try downloading a previous version? Either that or developer could be set to basic. I know you said you were helped out but what was the fix for your issue?
Old Jul 5, 2014 | 06:56 PM
hutch959's Avatar
select field.
click on "edit"
Set Data
then enter it in.
that was my issue..... you cant just enter in the data in that field.
Old Jul 8, 2014 | 07:27 AM
jrainwater's Avatar
Or hit the = sign
redSLed
Jan 2, 2018 12:04 PM
mrfred
Sep 17, 2017 06:11 AM
lncrphish
Lancer Engine Management / Tuning Forums
15
Aug 3, 2010 06:48 AM
Muad
Sep 11, 2007 07:56 AM
