ROM read problem
Old Apr 3, 2011 | 09:14 AM
nazzal's Avatar
ROM read problem
what is that any idea
Old Apr 3, 2011 | 09:33 AM
artisticspawn's Avatar
I had an issue with mine reading my ROM off my car. I then ran the ECUFlash ECU Inlocker 2.0 first, then ECUFlash and was able to successfully gain access to the ROM off the car. Hope that helps.
Old Apr 3, 2011 | 09:39 AM
nazzal's Avatar
i have tryed that but not working
Old Apr 3, 2011 | 11:38 AM
todd6027's Avatar
try reading the rom with the eng running
Old Apr 3, 2011 | 01:34 PM
nazzal's Avatar
i have tryed to do that also but no use it will show the same massge
Old Apr 3, 2011 | 01:36 PM
fugiwara's Avatar
what ver of cable you have? could be a bad cable, I had problem with cable and I returned for a new one.
Old Apr 3, 2011 | 01:56 PM
nazzal's Avatar
i have tryed the 1.3 and the 2.0 and both worked in other car very well
Old Apr 3, 2011 | 02:04 PM
todd6027's Avatar
if it logs ok check wiring loom between white init plug and ecu
Old Apr 3, 2011 | 02:24 PM
nazzal's Avatar
mmmm i will check that in the morning and keep you updated
Old Apr 3, 2011 | 10:24 PM
nazzal's Avatar
any other suggestion
