first start problem
Old Apr 19, 2011 | 12:36 AM
stunt2's Avatar
first start problem
car won't start on first and second try when the engine is cold. only at third try it bogs like impreza for a second and then starts ok. It's an e3 with 96530706, injector size and latency scaled for 510's. all other injector/kranking tables are untouched
what tables should I change and how, to sort this cold start problem
Old Apr 19, 2011 | 02:09 AM
MercenaryX2's Avatar
You're probably getting too much or not enough fuel. Try adjusting the MAF scaling between 19-50 and see if you get anywhere.
Old Apr 25, 2011 | 11:09 PM
stunt2's Avatar
adjusted the MAF. before my afr was ~12.0 at Idle, now it reads 14.7 but kranking problem still remains
Old Apr 27, 2011 | 12:34 PM
stunt2's Avatar
anybody ?
Old May 8, 2011 | 01:54 PM
stunt2's Avatar
bump
Old May 8, 2011 | 11:03 PM
testa corse's Avatar
you need to fine tune cranking not idle
Old May 9, 2011 | 12:39 PM
stunt2's Avatar
which tables axactly and how ?
Old Sep 2, 2011 | 03:30 AM
stunt2's Avatar
bump
