This look like MBT?
Old Apr 19, 2011 | 05:12 AM
Benja's Avatar
This look like MBT?
Hey dudes,
Pretty positive i've hit MBT finishing off the tune on the Prancer tonight.
Upped the mid range timing with nice 10-15tq gains.
Upped the timing above 6k with no gains at all, 2 back to back pulls showed no gains, dropped it back to the previous setting and torque stayed the same.
Fuel is ~E70-75.
Graph below.
First run is the average out of 3 base lines.
Second run is added mid range timing, and the higher top end timing
Third run is the added mid range timing, but the top end timing of the first run.
Old Apr 19, 2011 | 06:36 AM
andrewzaragoza's Avatar
i can't be positive if its past mbt. but i think you could use a few more psi of boost.
Old Apr 19, 2011 | 06:51 PM
03whitegsr's Avatar
Depends on how consistent you were with the pulls. Same stretch of road, going the same direction, starting at the same speed and run conditions (ECT, throttle application, similar driving conditions before the pull, etc.) How do the 3 baseline runs compare? Do they have max/mins above and below the test runs? If so, you might not be getting consistent enough pulls to find MBT at all.
Did you try upping the mid-range timing any further?
Looks like 5500-6500 might be about right, 6500+ might actually prefer the higher timing so you may not be ramping it in fast enough. Hard to say though, could just be the smoothing.
Old Apr 19, 2011 | 08:09 PM
project_skyline's Avatar
What is your timing at now?
Old Apr 19, 2011 | 11:19 PM
Benja's Avatar
Same stretch of road, same direction, start point.
3 baseline pulls were within 3nm of each other.
Old Apr 20, 2011 | 11:19 AM
03whitegsr's Avatar
Mind posting a plot with just your 3 baseline pulls? Just looking to see how consistent your data is, not really concerned about the peak numbers though.
Old May 18, 2011 | 08:36 PM
C130flyer's Avatar
seems rich to me, add more boost and lean it out to 11.8
Old May 18, 2011 | 11:00 PM
Its running 12:1 ish right now, i think your looking at the boost side.
PIE-R
Dec 21, 2019 08:14 PM
darwin_evo
E85 / Ethanol
10
Jul 10, 2017 07:57 AM
l2r99gst
Midwest Region
11
Jun 14, 2010 02:20 PM
tonyboy
Feb 28, 2010 05:08 PM
SlowCar
Sep 18, 2005 12:53 AM
