SST MR/SE 1st gear TPS limiter FOUND!
Old Jun 16, 2011, 01:20 PM
  #121
sohcpunk's Avatar
Originally Posted by BakaUnchi
nope i dont like to reply to emails sorry....
I can flash this for you no problemo call ronnie and make an appointment
Thanks Jon for applying this to my car today. Upon initial testing (mashing the gas pedal from a stop) I was able to obtain wheelspin right when it hits boost. I will try launching it with the left foot on the brake when I have some time and an open lot.
sohcpunk is offline
Old Jun 16, 2011, 03:52 PM
  #122
BakaUnchi's Avatar
W00T
BakaUnchi is offline
Old Jun 16, 2011, 04:44 PM
  #123
sheeley91's Avatar
jon for the win
sheeley91 is offline
Old Jul 7, 2011, 01:13 PM
  #124
TheXRider's Avatar
I just got tuned and had the restriction removed and set at 100%, but it doesn't feel how I expected from a dead stop I punch the gas and it feels like it has a stall to like 3000rpms and then it kicks in. I know there is boost lag, but it feels to sluggish from a dead stop. Does this sound right if the settings where changed to a 100%?
TheXRider is offline
Old Jul 7, 2011, 01:39 PM
  #125
sohcpunk's Avatar
Sounds about right. You have to realize that our car's power potential comes on when boost is hit. From 0-3000rpm you won't notice a difference because boost hasn't been engaged. But after that, that's when it really punches the car and Mitsubishi applies the limiter to protect the SST. Now that it's removed, you will feel much more only during boost.
The correct way to do it is to put the car into S-Sport, turn off traction control, , left foot brake and right foot gas to 3-5K and take off! That way, you will always be in boost from the time you move.
sohcpunk is offline
Old Jul 7, 2011, 05:43 PM
  #126
sheeley91's Avatar
Exactly what he said :-)
Old Jul 7, 2011, 08:26 PM
  #127
TheXRider's Avatar
Got it...
Old Jul 7, 2011, 08:44 PM
  #128
tephra's Avatar
does it sound like the clutch is slipping? ie does it like sit and hold a certain rpm for a bit longer than normal?
tephra is offline
Old Jul 7, 2011, 09:14 PM
  #129
TheXRider's Avatar
I don't think that's the cause all I have on my SE is an intake and a 3" straight pipe from the DP back. It made 315hp and 329 torque on 27psi
Old Jul 7, 2011, 09:19 PM
  #130
EvoM Community Team
migs647's Avatar
Get a boost gauge installed, you'll see that boost doesn't start kicking in until 3-4k. It will give you an idea when to expect power as well.
migs647 is offline
Old Aug 2, 2011, 11:22 AM
  #131
Hiboost's Avatar
Fun fact of the day when doing some baseline adjustments on my new car:
2011 Evo X MR
rom: 56900010
1st Gear TPS Limiters all read 100% from the factory.
Now don't all go out and blow your SST Trannies doing a launch and blame me though!
Hiboost is offline
Old Aug 2, 2011, 11:23 AM
  #132
RazorLab's Avatar
Received 1,044 Likes on 762 Posts
2011 Evo X MR
rom: 56900010
yea they limit 1st gear with the boost tables now.
1st gear - 75% (instead of 100%) WGDC in Reactive until 5500rpm, 0% WGDC in passive until 5500 rom
RazorLab is offline
Old Aug 4, 2011, 03:29 PM
  #133
Hiboost's Avatar
Ahh good to know, seems a little soft coming off the line still so a bit of tweaking should net a happy balance.
Hiboost is offline
Old Aug 4, 2011, 07:37 PM
  #134
user 629782012's Avatar
Originally Posted by foreigner
Is Any boddy else have made this test on his MR or SE; please Post your experience, thanks
Can anyone explain how? and i'll attempt it?
user 629782012 is offline
Old Aug 4, 2011, 08:15 PM
  #135
WW IX RS's Avatar
Damn! Im kind of glad I went with an SST car this time around! It looks like things are coming along nicely for the twin clutch cars. =]
WW IX RS is offline
Quick Reply: SST MR/SE 1st gear TPS limiter FOUND!
