Uncontrollably RICH
Old May 19, 2011 | 09:16 AM
stunt2's Avatar
the screenshot is from Tephra V7 rom
if you have the standart rom, table names are still the same, they shoud be located in category "Fuel"
Old May 19, 2011 | 11:11 AM
EatSleepBoost's Avatar
ok i will check when i can in a few hours
Old May 19, 2011 | 05:33 PM
yea i have v7 as well but my values look different and are named different for the throttle. iv attatched the screenshot
Old May 23, 2011 | 03:57 PM
I saved 4 different versions of my rom all with one change made to them to try and correct my problem. Yesterday i tried all 4 and none fixed my issue.
Things i tried are
-Periphery bit 4 to 0
-Bradley's latency for the 2150's
-Raised my injector scaling (I read on a thread on here to raise it if you are running to rich at idle)
I forget the last one as i am at work now on a different computer.
I am quite stuck. any other sugestions??????
Old May 23, 2011 | 04:22 PM
Fast_Freddie's Avatar
Veteran: Navy
https://www.evolutionm.net/forums/ec...nimum-ipw.html
Old May 23, 2011 | 04:34 PM
i don't see my rom listed on that thread??
Old May 23, 2011 | 04:39 PM
bdid's Avatar
don't know if you checked already but did you monitor the o2 sensors activity?
Old May 23, 2011 | 07:22 PM
my evoscan is currenlty messed up. i can't seem to find the download link to re download it. I still have my old key but can't find the download
Old May 23, 2011 | 07:56 PM
Veteran: Navy
97140015
Code:
<table name="Minimum IPW #1 SHLL2->NOP (0x4908 -> 0x0009)" category="Misc" address="26D2E" type="1D" scaling="Hex16"/>
<table name="Minimum IPW #2 SHLL2->NOP (0x4908 -> 0x0009)" category="Misc" address="26D30" type="1D" scaling="Hex16"/>
<table name="Minimum IPW #3 SHLL->NOP (0x4900 -> 0x0009)" category="Misc" address="26D32" type="1D" scaling="Hex16"/>
<scaling name="IPW16:SHLL0" units="ms" toexpr="x*8/1000" frexpr="x*1000/8" format="%.3f" min="0" max="65" inc="0.008" storagetype="uint16" endian="big"/>
<table name="Minimum IPW SHLL0" category="Misc" address="1502" type="1D" scaling="IPW16:SHLL0"/>
