I cant log my lc1 help please!!!!
Old May 24, 2011 | 09:48 PM
herwick evo's Avatar
so i been trying to log my A/F with evoscan 2.8 and i cant seem to get it to work doesnt matters what i did ,she is still fighting me hardcore,any suggestion guy,may be im not computer junkie but i have try and try to change all the setting and comp ports still nothing,thanks guys.....
Old May 24, 2011 | 09:51 PM
erickponce's Avatar
do you have a db gauge with your lc1?
Old May 24, 2011 | 09:56 PM
sorry but is what is db mean,i have an innovatetive lc1 is black and it displaying red when it on,has a red button on the dash to recablarate,thanks
Old May 24, 2011 | 11:23 PM
stunt2's Avatar
have you connected 'terminator plug' in LC1-s serial-in cable ?
Old May 25, 2011 | 08:04 AM
tiggeryellow1's Avatar
Veteran: Army
Lightbulb
+1... Make sure you are plugged into the OUT cable on your LC1 with your serial cable. Also do you have a serial port on your notebook, or are you using a USB to serial cable. If you are using a USB to serial cable make sure you have all your drivers downloaded. I ran into that problem when I changed out logging notebooks. One had XP the other Windows 7... when I couldn't get the drivers for the USB Drivers for the Windows 7 notebook I couldn't get Evo Scan to recognise my LC1 either.
Old May 25, 2011 | 09:36 PM
yes i did connect the plug,and i did the newest drivers for it too,but im using the prolitic serial to usb addapter that i bought from evoscan webside ,they said it work best for it ,uhhhhhhh
Old May 25, 2011 | 09:44 PM
erickponce's Avatar
the db gauge is just the gauge that comes with some of the kits with the LC1
Old May 26, 2011 | 07:31 AM
Veteran: Army
Hmmmmm and you said that you have a steady red light... it's not flashing? If so I would check Innovates web forum or give em a call? If it had been a few years ago it could have been an evoscan glitch; I know I had a similar issue but that was back in like 07. As evolved as evoscan is now I am pretty sure it's not the problem. I don't know bro
Old May 26, 2011 | 10:03 AM
erickponce's Avatar
i know that grounding is a big issue with these but i dont know if that would mess with logging. Make sure all your grounds are connected at the same point
Old May 26, 2011 | 12:53 PM
partyboy1122's Avatar
A simple thing to check:
Make sure you have the correct COM port selected.
Old May 26, 2011 | 07:53 PM
i checked all the grounding ,change all the ports plug it in the out plug,the gauge work great reading fine ,just cant get it to log so i can fine tune it ,,should i try with a different wideband at this point,thanks for all the help guy.....
Old May 26, 2011 | 08:00 PM
prowakeskater's Avatar
cant get mine to log either. **** Lc-1's
Old May 26, 2011 | 09:40 PM
Veteran: Army
Ok so we have verified that it's not the LC1... Is it like it was fine before and ALL of a sudden its not working or have you not been able to log at all period?
UxC
Dec 19, 2016 08:43 AM
JDM EVO 6
AEM EMS
Jan 3, 2016 01:33 PM
Slo_crx1
Jul 25, 2010 07:41 PM
sponners
Apr 20, 2008 12:30 PM
heSOshAdy
Oct 25, 2007 07:30 PM
