need some help with software
Old Jun 15, 2011 | 06:54 AM
Srr's Avatar
Srr
i need to get the evo flash or evo scan software to tune my car... i already have the tatics cable
can someone point me in the right direction?
i search and found a few links but id rather someone on here with better knowledge inform me
thanks
Old Jun 15, 2011 | 07:01 AM
laramie_05MR's Avatar
http://openecu.org/index.php?title=Main_Page
http://www.evoscan.com/
Old Jun 15, 2011 | 08:12 AM
Srr's Avatar
Srr
thanks i just downloaded the evoscan.. now i have another issue... when i try to "read from ecu" i keep getting error message "usb cable in use or not connected"
but if i use the ecuflash program to read the ecu it works fine...
any ideas? the battery is good and i have a tripple charger on it
Old Jun 15, 2011 | 08:48 AM
Srr's Avatar
Srr
also if i use the evoscan to read my diag codes it connects fine...
Old Jun 15, 2011 | 08:51 AM
tiggeryellow1's Avatar
Veteran: Army
1) Did all the drivers download and install properly when you downloaded evoscan?
2) What version of evoscan did you download?
3) What OS is currently on your notebook?
Old Jun 15, 2011 | 09:19 AM
Srr's Avatar
Srr
1 yes it was all installed i can try to reinstall
2Download EvoScan v2.8.0005
3 windows 7
thanks
Old Jun 15, 2011 | 08:05 PM
Veteran: Army
U g 2 g?
Old Jun 16, 2011 | 06:39 AM
Srr's Avatar
Srr
Originally Posted by tiggeryellow1
U g 2 g?
what??
Old Jun 16, 2011 | 07:27 AM
Veteran: Army
My bad are you Good 2 Go? I didn't see anything else so I am assuming you figured out whatever the problem was. U good?
Old Jun 16, 2011 | 12:25 PM
Srr's Avatar
Srr
nope..same problem ...it keeps telling me usb in use cannot connect
Old Jun 17, 2011 | 12:03 AM
Veteran: Army
Ironically mine seems to be acting weird now also... and on my windows 7 pc, but not my XP. Damn.
Old Jun 17, 2011 | 12:55 AM
Veteran: Army
Do you have the 32 or 64 bit encryption... I just uninstalled my 2.8 and rolled back to the complete 2.7.0090 and everything seems to be working fine... but I have 64 bit.
Old Jun 21, 2011 | 07:26 AM
Srr's Avatar
Srr
how do i know what bit i am using....?
Old Jun 21, 2011 | 07:31 AM
Veteran: Army
Right click on the My Computer Icon on your desktop, scroll down to properties and all the information about your system should be under the General Tab as far as your system properties go.
Old Jun 21, 2011 | 07:38 AM
Srr's Avatar
Srr
ok thank u, it says 64 bit
