Done tuning... Or am I?
Old Jun 24, 2011 | 02:30 PM
Jogi's Avatar
"Finished" tuning for today. Any insight? Comments?
Car: 2003 Evo 8 Stock motor
HKS GTII 7460R turbo running 26-27psi
HKS 272 Cams
FMIC
Intake,fuelpump,mbc...
EU 100 octane.
Maps pictured below.
Code:
Attached log since it's all messed up if posted here
File Type: zip
Old Jun 24, 2011 | 02:41 PM
Raptord's Avatar
Not the best way to post a log on the forum I think, lol. Columns are all messed up.
Other than that, looks good to me.
Old Jun 24, 2011 | 02:46 PM
Jogi's Avatar
Attached the log aswell now in zip.
Old Jun 24, 2011 | 03:30 PM
Raptord's Avatar
Much easier to read, thanks
13's might be a tad too lean above 250 load, but other than that I maintain that it looks good!
Old Jun 24, 2011 | 04:24 PM
Fast_Freddie's Avatar
Veteran: Navy
Looks good, it is 100oct so should be relatively safe...
Old Jun 24, 2011 | 04:54 PM
evo8426's Avatar
I think the fuel is 100 RON since he is in Europe, so it would be like 95oct here in the states.
Old Jun 26, 2011 | 02:53 PM
stunt2's Avatar
maby a noob question but what does that -15 timing mean at 5-7K rpm and 0-30 load ?
Old Jun 26, 2011 | 02:58 PM
evo8426's Avatar
fireballs out of the exhaust
Old Jun 26, 2011 | 04:57 PM
CMB's Avatar
CMB
IMO you can use more timing up top
Old Jun 26, 2011 | 05:07 PM
Veteran: Navy
Didn't even see that! Perhaps richen up ther AFR to around 11.5 and call it a day...
Old Jun 26, 2011 | 06:02 PM
Dynotech Tuning's Avatar
FYI, you very well can pass thru those -15* cells if you 'lift' shift'. This is known to cause 'shift knock' at times so do some logs and see if you are having any issues with that.
-Jamie
(aka jack_of_trades)
Old Jun 26, 2011 | 06:24 PM
Raptord's Avatar
-Jamie
Couldn't those values be for some sort of anti-lag effect? (or cool backfires, lol)
Old Jun 26, 2011 | 07:13 PM
Yes, people do it to try and build more boost when launching or to try and shoot flames but we have found that this can cause shift knock at times. This is one reason that TephraV7 has separate Launch Maps.
-Jamie
mx4life85
12
Feb 8, 2014 08:21 PM
elhuberto
Jan 5, 2013 06:54 AM
Jossue
Aug 13, 2011 03:56 PM
eyekyu
10
Apr 5, 2011 12:55 PM
EVOheaven
May 6, 2010 04:47 PM
