ECU flash doesn't recognize ROM
Old Jul 12, 2011 | 09:57 AM
pshooter's Avatar
Picked up my open port 1.3 cable. I read my ECU in evoscan. When I try to read the hex file into ecu flash 1.3 or 1.42 it doesn't recognize the file.
Any suggestions?
Old Jul 12, 2011 | 05:50 PM
dparrish's Avatar
Post the rom file here and someone (me) will take a look.
Is there a reason for using evoscan to read the rom instead of ecuflash?
Old Jul 12, 2011 | 05:54 PM
tscompusa2's Avatar
most likely you dont have the XML file for that particular rom on your computer in Program
Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Old Jul 12, 2011 | 08:49 PM
AndyCT9W's Avatar
This might work. Try to open the file and use the option for developers only, inherit the evo 9 base definition then add all your details that you can (you might not know a couple of them). Then hit finish and look at the rom info provided. Look at the internal Id and that should be the XML you are missing. Then search or ask for the XML file on here.
I am going through exactly what you are right now. And this got me a bit further, I just wasn't able to get the complete XML file I needed.
Old Jul 12, 2011 | 08:51 PM
AndyCT9W's Avatar
When you get the XML file you need to go into openecu/rommetadata/Mitsubishi/evo (i think that's the location, at work on iPhone sorry) and put the XML file in there.
Old Jul 12, 2011 | 10:46 PM
dparrish's Avatar
If you can work out the rom id yourself, there are a large amount of ecuflash XML files at http://code.google.com/p/ecurom/sour...tsubishi%2Fevo
Old Jul 13, 2011 | 06:47 AM
jmcmill3's Avatar
that fixed my issue, thanks...
Old Feb 5, 2015 | 05:06 AM
wamang's Avatar
map did not show mivec setting
hi:
I use ecu flash to reading my ecu but the mivec adjusting cannot show out
can any one help ? mine is evo wagon ct9w manual 6 speed
thankyou
GrabbinGears
Jul 7, 2016 02:19 PM
turboback1243
Sep 27, 2015 02:38 PM
rich3389
Jun 29, 2013 11:48 AM
EvoXHoosier
Mar 15, 2011 06:18 PM
cij911
Aug 12, 2010 11:46 PM
