Evo Scan Question
Evo Scan Question
So I thru a code today. Busted out my laptop and opened evoscan V2.7 to read the code. I connected to the data logger first to make sure i had a solid connection. Went to run for the codes, connected fine but at the end it stated the following
Info: CPU Timer Factor Applied: 0
Info: Initialization Complete...
Info: OBDII Sync Byte Received.
Info: Keybyte Response: 0x08 0x08
Info: OBDII Keyword CRC Received.
Info: Waiting for vehicle ecu...
Info: Arithmetic operation resulted in an overflow.
Info: Check DTCs Complete.
no codes were pulled from ecu. just kept giving me the overflow notice.
Has anyone seen this Arithmetic operation post before? If so how do I fix it, I cant find any info on this at all.
Thanks
Thanks
I am getting the same thing I have completely deleted all of evoscan and ecuflash I even cleared all the drivers off the lap top. Re installed everything and still no dice it's getting frustrating!!
I have gotten that message before too, when I tried connecting with the key off, after turning the key on I still get that error message but if you exit out of evoscan and open it back up it works. Not sure if this might be your issue or not just fyi.
GeoMitsu
Sep 20, 2016 09:36 AM
tboboy
Apr 29, 2010 11:58 PM
