Strange TPS related cut problem. Tephra ROMs
Old Aug 7, 2011 | 01:07 AM
84ace's Avatar
*FIXED*Strange TPS related cut problem. Tephra ROMs
Hi all,
I have a 2001 EVO VII JDM GSR which originally ran the 98640014 stock rom, with this rom i am able to accelerate at WOT to redline with no hassels, as expected. I have downloaded the Tephra v5.10 90550001 rom and payed for the V7 rom as well.
With those two maps i have a problem where if i accelerate at WOT i get this strange cut, and the car bucks back and forth. I have done some logging last night on the stock rom and the Tephra V7 rom.
The results can be found below:
I am leaning toward increasing the fuel cut load x1 values to try and get around this problem. Does this sound like a solution or am i off track?
I am only new to this and trying to learn as fast as i can. I have found this forum very informative.
Thanks,
Acea
Attached Thumbnails Strange TPS related cut problem. Tephra ROMs-stock-map.png   Strange TPS related cut problem. Tephra ROMs-tephra-not-full-throttle-run.png   Strange TPS related cut problem. Tephra ROMs-tephra-tps-problem.png
File Type: zip
Old Aug 7, 2011 | 02:31 AM
84ace's Avatar
I have just completed logging several WOT runs back to back. I changed the fuel cut load x1 parameters and nothing changed. All i can tell is that it does not happen until the 3000rpm mark or over. I accelerated past 3000rpm with the TPS not at 100% and then pushed the accelerator to the floor, the problem occured at whatever RPM i was at when the pedal hit the floor.
This has me stumped, i have gone over the new log and nothing seems the same when it happens, other than it occuring around 3000rpm for most runs.
Any ideas?
File Type: zip
Old Aug 7, 2011 | 03:24 AM
84ace's Avatar
As requested.
Attached Thumbnails Strange TPS related cut problem. Tephra ROMs-fuel-cut-values.jpg
Old Aug 8, 2011 | 07:40 PM
dr_latino999's Avatar
Veteran: Army
Any ideas yet? I've run into a similar issue while testing Tephra today on a 2004 Evo VIII. 6.5K RPM and I'm hitting a wall.
Old Aug 8, 2011 | 11:30 PM
84ace's Avatar
No idea at all yet. I have looked into lots of things and changed all that seems relevant to no avail. Problem still exists. I might have to shoot Tephra an email and ask him if he has any ideas.
I find it hard to believe that no one knows whats going on. Surely someone has a clue as to what is happening and how to fix it.
I have become annoyed with the two affected ROMs and switched back to the stock ROM for the time being, I added in some boost and took away some timing, that will keep me busy for now or until i can shed some further light on the problem.
Sorry i can't be of help.
Old Aug 9, 2011 | 05:50 AM
BigT's Avatar
You're dragging your foot on your clutch pedal ever so slightly and engaing NLTS. Either disable it or raise your left foot.
It happens a lot to me too, FYI...
Old Aug 9, 2011 | 11:34 PM
And's Avatar
And
you don't have valet enabled do you? for 3000rpm? and its not disengaging correctly, just wondering if you raise the rpm level
Old Aug 9, 2011 | 11:43 PM
philr8's Avatar
Disable NLTS!!!!! It doesnt work on some JDM Evo 7's
Ive encountered this on almost every JDM Evo 7 Ive tuned, that simply dont like NLTS
This will fix your issue 100% (hopefully )
Old Aug 10, 2011 | 01:14 AM
84ace's Avatar
Mate, your a legend. Problem solved.
I would like to thank all who posted. If anyone ever comes to Darwin drop me a message, i will buy you a beer.
Thanks
Acea
Zunk87
Sep 1, 2016 03:22 PM
br3akrboi
Dec 6, 2015 11:40 AM
TouringBubble
Aug 3, 2015 09:15 PM
GreeceS13
Sep 12, 2014 01:18 PM
