boost cut limit
Old Aug 19, 2011 | 02:24 AM
kiwiracer's Avatar
Question boost cut limit
Im running a sd v7 rom, has a boost cut at 319 load how can i up that?
also if im running about 30 psi boost what figure do i have the 1 byte/2 byte setting on? 1.2? 1.3? 1.4?
help would be appreciated.
Making 400kw at wheels today on factory ecu yippie
Old Aug 19, 2011 | 03:14 AM
Dynotech Tuning's Avatar
Change the setting for the 'fuel cut multiplier' so it doubles the fuel cut limit from 319 to 638. Then just set the 'fuel cut table x 2' or whatever it's called lol.
You can lower the SD 'MAP KPA vs. Load' table so the peak load you achieve is whatever you'd prefer.
Old Aug 19, 2011 | 10:47 AM
BarryC's Avatar
any chance someone could find this mod for 88570008 please
Old Aug 19, 2011 | 02:58 PM
kiwiracer's Avatar
Already done that but that still doesnt allow me to change the boost cut load box under global boost settings... its the boost cut i dont want not the fuel cut.
still reads 319 but i know the other box u mention reads 638 and yes i had already selected table 2 .
Kaveeth
Jan 26, 2015 05:35 PM
Anubis18
Jun 23, 2013 11:43 AM
Mellon Racing
May 10, 2012 06:34 PM
fatboyz39
May 11, 2011 10:40 AM
sponners
Jun 10, 2008 04:50 PM
