cant log adc / ayc on evoscan Help
Old Sep 18, 2011 | 08:00 AM
neilm's Avatar
Originally Posted by donner
The same in my cable but I don't know about car OBD plug, I just needed to connect my test bench ecu pin 46 to OBD port pin 1 to make datalogging work. And I noticed datalogging only works with 1.3, not with 2.0.
i going to see if 46 adc plug is linked to pin 1 odb plug now with the multimeter
and all so pin 35 and pin 7on the odb
Old Sep 18, 2011 | 08:55 AM
neilm's Avatar
has any one got a good evo 7 rhd pin out for the adc plugs
Old Sep 18, 2011 | 10:02 AM
neilm's Avatar
so i have test the above and all is ok both are linked
46 is going to pin 1
and 35 is going to pin7
were do i go now ???
should i link pin 1 and pin 15 on the odb plug as the cable side is liked ????
Old Sep 18, 2011 | 10:31 AM
donner's Avatar
Just found this from Evoscan website:
Evo4/5/6/7/8/9 AYC & ACD & ABS Datalogging and AYC / ACD Air Bleeding (MUTII/MUTIII) (if this doesn't work for you, then remove pin9 with pliers, if this still doesn't work for you, then send the cable back for one of the latest openport 1.3U models that does)
Link:
http://www.evoscan.com/evoscan-gps-o...flashing-cable
Old Sep 18, 2011 | 10:48 AM
neilm's Avatar
Link:
im going to send them a email about it and see what they say
Old Sep 19, 2011 | 12:51 PM
neilm's Avatar
so iv got it to connect to the AYC only using the op2 cable
but the info been logged is not right / staying static
going to remove pin 9 on the odb2 plug and see if that helps
Old Sep 23, 2011 | 11:16 AM
neilm's Avatar
so iv removed pin 9 from the odb2 plug
its still not working
only connecting to ayc and all the info is wrong
any one got any pointers were to go next
Old Oct 2, 2011 | 07:47 AM
neilm's Avatar
just bump this up and one got any info about this
no matter how small
Old Oct 2, 2011 | 08:33 AM
donner's Avatar
no matter how small
Did you contact evoscan and if yes, what did they say about it? Like I posted earlier there seems to be something in the cable, some models work and some don't.
Do you have possibility to try with another cable (1.3U)?
Old Oct 2, 2011 | 08:42 AM
neilm's Avatar
il try get a newer 1.3u cable a friend has and test it out
this was the reply i got from evoscan
i just email them back there i hope i can get this sorted
as it would be nice to have it working for bleeding etc
"have pin 9 twisted out of the 1.3 cable" <- good
that is correct. this will allow it with evoscan v2.8. can you datalog ABS/AYC/ACD ? maybe someone has cut your pin1 cable to your ecu, please check it all the way to the ecu
do not link pin 1 and 15 on op1.3U that is for openport 2.0 cables only.
Old Nov 1, 2011 | 02:54 PM
neilm's Avatar
bump this up any one have any input on this
or other threads to read up on iv been searching but not much has showed up
mrfred
May 1, 2020 10:16 AM
blockade35
Jul 12, 2016 08:52 PM
stokEd
51
Oct 14, 2015 06:44 PM
Evo_AK
16
Sep 28, 2015 12:26 PM
jamiestsi
Feb 29, 2012 02:31 PM
