Where is the mitsulogger software?
Old Nov 2, 2011 | 09:42 AM
1BADSS/SC's Avatar
I have evoscan 2.8 but apparently it hates my UEGO aem WB. I have the blue cable attached to pin 2 and pin 5 grounded on one of the ground points in the dash. Evoscan doesnt acknowledge its existence. Ive heard that mitsulogger is just as good as evoscan and will work with my aem, however I cant find the damn software anywhere. Does anyone know where I can download it on a functional link? If not, where can I get evoscan 0.99 at considering I didnt see it when I logged into the evoscan website. I really hope all these issues are finally panned out when 2.9 comes out....
Thanks in advance.
Old Nov 2, 2011 | 09:57 AM
binky's Avatar
Evoscan 2.8 and my AEM UEGO work just fine together.
How are you connecting the AEM UEGO to your computer?
The AEM output is serial (RS232) and unless you have an RS232 port on your laptop, you'll need an RS232 to USB converter. Then is just a matter of installing the drivers and then selecting the correct COM port.
I would get an RS232 to USB converter that has light indicators on it, this way you know information is being transmitted. I use this one made by Belkin and it works great: http://www.belkin.com/IWCatProductPa...duct_Id=459431
Also, mitsulogger is much older and I don't think its developed anymore. Evoscan is your best bet with the stock ECU.
-Bink
Old Nov 2, 2011 | 09:59 AM
catman78's Avatar
do this:
https://www.evolutionm.net/forums/ec...ial-cable.html
works with version of 2.8. I could not get serial cable to work with 2.8
Old Nov 2, 2011 | 10:10 AM
1BADSS/SC's Avatar
I have the serial to usb adapter and it isnt working. I have the blue cord hooked up to the 2 pin, the 5 pin grounded and the white cord taped off.
Old Nov 2, 2011 | 10:20 AM
binky's Avatar
The issue sounds like wiring and not Evoscan.
Did you wire your's like this?
https://www.evolutionm.net/forums/ev...ial-cable.html
FWIW, it took a few tries to get the wiring correct (as in making sure everything was making contact and that I had a good ground).
-Bink
Old Nov 2, 2011 | 11:09 AM
1BADSS/SC's Avatar
-Bink
See i cant do that though. I dont have a 9 pin adapter on my laptop so I have a seriel to usb piece.
Old Nov 2, 2011 | 11:15 AM
binky's Avatar
You need to wire it just like that guy did, then use the RS232 to USB converter.
You don't need to have that connector built into your laptop, that's what the converter is for.
-Bink
Old Nov 2, 2011 | 11:16 AM
1BADSS/SC's Avatar
Originally Posted by catman78
do this:
thanks for the info. My question thiough is all you need to do for this is splice into the pin 73 wire without actually severing it correct?
Old Nov 2, 2011 | 11:34 AM
1BADSS/SC's Avatar
-Bink
ok. I will try and rewire it up again sometime this week. I hope it works because I really dont feel like cutting up pcm wires...
Old Nov 2, 2011 | 11:43 AM
binky's Avatar
You can buy a pre-made cable here:
https://www.evolutionm.net/forums/ve...torsports.html
-Bink
Old Nov 2, 2011 | 11:55 PM
1BADSS/SC's Avatar
thanks for the info. If I cant get mine to work I will probly go this route
darkmitsu
Lancer Engine Management / Tuning Forums
141
Dec 31, 2022 05:41 AM
bustin
Mar 18, 2018 05:44 PM
ehall20
Jun 9, 2015 07:01 PM
ehall20
Apr 3, 2014 03:38 PM
rawkus
Oct 4, 2013 05:47 PM
