RAX Patch - ROM patches
Old Dec 27, 2012 | 03:08 PM
  #151
evoscan's Avatar
Silver Sponsor
Originally Posted by khaydin
One weird thing that happened before the flash that broke my car was that I plugged in my tactrix cable and windows re-installed the driver for it. Not sure why it did that as I haven't updated Ecuflash or Evoscan in several weeks.
this is normal for windows, because each different usb port in your pc stores separate drivers, so you plugged it into another usb port on the same laptop that you haven't used before with that cable.
Old Dec 27, 2012 | 08:16 PM
  #152
richardjh's Avatar
Thanks Hamish.
Rich
Old Dec 28, 2012 | 08:26 AM
  #153
khaydin's Avatar
Yeah I understand that, but my laptop only has 2 USB ports (same side, right next to each other) and I haven't reinstalled windows in over a year on it. I know it's been plugged into both of the USB ports previously.
Old Dec 28, 2012 | 06:45 PM
  #154
richardjh's Avatar
Originally Posted by momostallion
i can say i just flashed this patch last week. i've flashed 4x since the patch with out issues.
Yeah, I've flashed a few times on it too.
I flashed my first decent version of RAX Fast Logging in my ROM revision #440. I'm now on revision #487. All up, 47-odd flashes. Around 20 for the patch development phase, and 27 more for reworking my CalFuelMap, HO Fuel Map, boost, MAP/MAFCalcs, load ramp rates, throttle thingy, track testing, etc.
So, as usual, I've beaten the living **** out of my ECU, SST, tyres, Tactrix and laptop. On my setup, no hint of wackness to date.
Rich
Old Dec 29, 2012 | 01:22 PM
  #155
Drkramm's Avatar
56890013 / 1.43.3252 / 2.9.0023 / RAX / ES+EF never open together solid 5+ flashes and 1 flash on the newest ecu flash (1.44.3719) I always have wifi disabled and nothing else open I run ecu flash do a test write then an actual write with out turning the ignition off inbetween ....
Granted the data set is small but everyone with a issue seems to have both programs open at the same time
Old Dec 30, 2012 | 10:31 AM
  #156
momostallion's Avatar
a new version of ecuflash was available (1.44.3719).
it lists a lot of changes. the most noticeable is a more consolidated method of rommetadata xml definitions. i haven't tested flashing with this version yet.
Old Jan 22, 2013 | 08:51 PM
  #157
richardjh's Avatar
Well, I'm closing the book on any supposed weirdness with flashing, RAX, EvoScan+EcuFlash being open together, etc.
We've given this thing enough time for any pattern to emerge. Plenty of updates received (thanks), and there is no pattern. It was just a cluster of various "things" happening... not related to any one issue at all.
Which is good.
Enjoy RAX!
Rich
Old Feb 20, 2013 | 02:17 PM
  #158
crak's Avatar
IS the fast logging applied to the GST maps rich?
Old Feb 20, 2013 | 03:04 PM
  #159
Hiboost's Avatar
My Evo won't be on the road again for another month or so but this looks like a nice mod to test out for the faster logging speeds.
Old Feb 20, 2013 | 03:12 PM
  #160
richardjh's Avatar
Sure is - v31 onwards.
Rich
Old Mar 31, 2013 | 10:22 PM
  #161
bellacotim's Avatar
Hi Rich,
Any chance you can give some love to 5959005 2013 X SST?
Old Aug 19, 2013 | 10:54 AM
  #162
mrwickd123's Avatar
Originally Posted by bellacotim
hi rich,
any chance you can give some love to 5959005 2013 x sst?
+1 for 59590004
Old Aug 19, 2013 | 04:18 PM
  #163
richardjh's Avatar
Sure, I'll take a look at these 5959 ROMs...
Rich
Old Aug 19, 2013 | 06:50 PM
  #164
Melloyellowevo's Avatar
Rich,
Thank you so much for making my life a ton easier to tune with your rax patchs and PSI based tuning (tephra / Golden). You guys are awesome!
Old Sep 2, 2013 | 01:01 PM
  #165
mrwickd123's Avatar
What's the difference between 58020005 and 58020105?
