RAX Patch - ROM patches
Old Jul 1, 2015 | 08:55 AM
  #181
chetrickerman's Avatar
Veteran: Army
Originally Posted by richardjh
Here's the patch XML stuff... attached.
Rich
Thank you
Old Aug 15, 2015 | 11:57 AM
  #182
Veteran: Army
Hey Rich, will the 56920006 patches work for 56920008?
Thanks
Old Aug 15, 2015 | 06:43 PM
  #183
richardjh's Avatar
Thanks
Nope - the 0008 ROM shifted stuff around...
Rich
Old Aug 16, 2015 | 06:43 AM
  #184
Veteran: Army
Any chance you can get the patch for 56920008 pretty plz?
File Type: bin
Old Aug 25, 2015 | 10:15 AM
  #185
Outer's Avatar
The download links are not working for me. Is anyone else having trouble with the downloads??
Old Aug 25, 2015 | 07:31 PM
  #186
richardjh's Avatar
Hi. Which one? I just tried the first one, and it downloaded fine...
Rich
Old Aug 26, 2015 | 06:19 AM
  #187
Outer's Avatar
58010005 but it seems none of them are working for me... Maybe the download links do not work outside Australia??
Old Sep 1, 2015 | 11:35 AM
  #188
Veteran: Army
Any chance I can get the patch for 56920008 pretty plz?
Old Sep 11, 2015 | 01:12 PM
  #189
Ambiguous's Avatar
Any chance I can get 56890013? The link seems to be dead/not working.
Old Sep 11, 2015 | 01:26 PM
  #190
vishwar1's Avatar
Yup I am not able to download the patch as well !
Old Sep 11, 2015 | 06:27 PM
  #191
richardjh's Avatar
I'll have to contact my ISP.
Rich
Old Sep 25, 2015 | 07:42 PM
  #192
richardjh's Avatar
Currently, I only have RAX Fast Logging for this one. Here, attached.
Rich
Old Sep 26, 2015 | 11:47 AM
  #193
Veteran: Army
Rich
Thank you!
Old Oct 1, 2015 | 02:42 AM
  #194
wenjie1812's Avatar
I'm making some EcuFlash-based ROM patches available. These have been developed and tested on my RA, and will now be available for some X ROMs... hence the "RAX" moniker.
RAX Patch contains:
1. IAT Adjusted BWGDC
2. SST Upshift Boost EC Management (SST models only)
3. Atmospheric Boost Baro Compensation
4. RAX Fast Logging
Details follow:
IAT Adjusted BWGDC
This patch makes it possible to adjust your Base Wastegate Duty Cycle in line with Intake Air Temperature.
A new table becomes available in the EcuFlash Turbo category:
The adjustment factor is applied directly to the relevant Reactive Solenoid Base WGDC Map lookup value, if that value is between 0% and 100%.
A Base Wastegate value of 0% will always remain 0%, irrespective of IAT.
A Base Wastegate value of 100% will always remain 100%.
SST Upshift Boost EC Management (SST Models Only)
This patch may be useful for reducing boost levels during SST upshifts at wide-open throttle. It will zero out any positive error-correction factor when RPM is dropping.
This patch will do something meaningful if:
  • Reactive Solenoid Max Total Upward WGDC Correction vs. TPS table is set up to allow upward/positive error correction.
  • Base WGDC and Boost Target tables are set up in such a way as to require the use of upward error correction in order to meet boost targets.
With boost error correction configured to suit, this patch will result in a lower wastegate duty cycle being used when a wide-open throttle SST upshift occurs, eg.
While this patch is no "magic bullet" for high boost during SST upshifts, it can help reduce the severity of the problem. That is, if your SST behaves like this in the first place - some do, some don't.
This patch makes it possible to eliminate the fixed Atmospheric Boost value when using Direct (psi based) Boost Control. The ECU will use BARO SENSOR reading in its calculations for boost targets.
Traditionally, psi-based boost control would offset the 3D boost target map values by a hardcoded "atmospheric pressure" constant, eg. "14.5". Boost targets would always operate in terms of absolute pressure.
This patch allows the ECU to use boost targets at relative (ie. gauge) pressure.
Two scaling modes are available. One caters for Direct Boost Control using the factory 3-Bar MAP sensor. The other supports the aftermarket Omni 4-Bar MAP sensor. Note: For Direct Boost with Omni 4-Bar, different patches are required in other areas of the ROM - RAX2 Patch does not deliver complete Omni 4-Bar support on its own.
The patch will only use the BARO SENSOR if the Atmospheric Boost fixed value is set to 0. A non-zero setting will bypass the patch.
RAX Fast Logging
This patch works with EvoScan v2.9.0023 or later to provide fast logging of 30+ items.
This one is big, and has an entire thread dedicated to it! See here for details!
RAX Patch Download and Documentation
RAX Patch comes in a set of EcuFlash XML definition files, for specific ROMs. The patch items should be straightforward to apply.
An important part of this release is a document containing detailed instructions on installing, testing and using the patches. This document (pdf) is included in the patch download.
PLEASE read the documentation in its entirety before applying, flashing, logging, driving, anything. There are detailed testing notes in that document - with useful logging addresses, and what values you should see in them. These notes have been included for your own safety (and peace of mind).
This document also contains Liability and Safety notices. Joy! Following in the best modern tradition of whacking everyone over the head with "use at your own risk" signposts, they are reproduced below, in tasteful red:
LIABILITY NOTICE
Incorrectly patched instructions can be extremely dangerous to your engine management, and can lead to severe engine damage. You assume ALL responsibility for the integrity of your ECU and engine management, vehicle safety, etc. If you are not confident in the procedures/data involved in the RAX Patch, do not make any change to your vehicle ECU's ROM image.
SAFETY NOTICE
It is important to testing any engine management change in a safe and thorough manner. Tests recommended in the related document are a guideline only. You assume ALL responsibility for the testing approach taken when using ECU ROM patches.
After all that, you're probably cowering under your desk in fear. On the off chance you're still with me, here is the download link, finally:
Downloads
RAX Patch EVO X SST v1r10: ROM 52690019-52690022
RAX Patch EVO X SST v1r10: ROM 53050006-53050007
RAX Patch EVO X SST v1r10: ROM 53050009
RAX Patch EVO X SST v1r10: ROM 54070007
RAX Patch EVO X SST v1r10: ROM 55580005-55580006
RAX Patch EVO X SST v1r10: ROM 56900007
RAX Patch EVO X SST v1r10: ROM 56900009-56900010
RAX Patch EVO X SST v1r10: ROM 56920006
RAX Patch EVO X SST v1r10: ROM 57140001
RAX Patch EVO X SST v2r05: ROM 58020005
RAX Patch EVO X SST v2r05: ROM 59590004
RAX Patch EVO X 5MT v2r05: ROM 52360018
RAX Patch EVO X 5MT v2r05: ROM 52680015-52680022
RAX Patch EVO X 5MT v2r05: ROM 52680024
RAX Patch EVO X 5MT v2r05: ROM 53040010
RAX Patch EVO X 5MT v2r05: ROM 54060007-54060008
RAX Patch EVO X 5MT v2r05: ROM 55570005-55570006
RAX Patch EVO X 5MT v2r05: ROM 56180001-56180002
RAX Patch EVO X 5MT v2r05: ROM 56870008
RAX Patch EVO X 5MT v2r05: ROM 56890007
RAX Patch EVO X 5MT v2r05: ROM 56890009-56890010
RAX Patch EVO X 5MT v2r05: ROM 56890013
RAX Patch EVO X 5MT v2r05: ROM 56910007
RAX Patch EVO X 5MT v2r05: ROM 58010005
RAX Patch EVO X 5MT v2r05: ROM 59580004
RAX Patch Ralliart SST v1r10: ROM 53600010
RAX Patch Ralliart SST v1r10: ROM 53610010
RAX Patch Ralliart SST v1r10: ROM 53610013
RAX Patch Ralliart SST v1r10: ROM 55590006
RAX Patch Ralliart SST v1r10: ROM 56940007
RAX Patch Ralliart SST v1r10: ROM 56950006
RAX Patch Ralliart SST v2r05: ROM 58030005
RAX Patch Ralliart SST v2r05: ROM 59570004
RAX Patch is built into razorlab's Ralliart Lancer Base Maps, v2.7 on.
RAX Patch Compatibility
RAX Patch v1 & v2 should coexist peacefully with TephraXMODv1.
RAX Patch v1 & v2 should coexist peacefully with the current Direct PSI-Based Boost Control patches (including Omni 4-Bar mode), as referenced in XMLs from www.goldenevo.com.
Special thanks must go to the brave souls who have been "first-run" testers for these patches for each supported ROM!
If you would like to email me about RAX Patch stuff (as opposed to just posting here), you can use:
raxpatch gmail com
If you would like to contribute to the RAX Patch cause, this works for PayPal too!
Cheers,
Rich
Use version V1 JDM 52360018 can help me?
Old Oct 1, 2015 | 07:26 AM
  #195
richardjh's Avatar
I got your message about tephraXMODv1. As per the text you quoted...
"RAX Patch v1 & v2 should coexist peacefully with TephraXMODv1."
So you should be fine to use 52360018.
Rich
